Im in the process of swapping out turbos for a Hypergear ATR43SS-2. I bought a water/oil line kit from Mamba, for Garret GT30, according to Tao. All fittings fit properly, except for the water return line. It has a -AN fitting to hose barb. From what I see, I need to remove hardline and install hose barb fitting to rubber line behind the head. I located the rubber line but is there an easier way to gain access without taking valve cover or intake manifold off?
https://www.sau.com.au/forums/topic/485874-rb25det-neo-turbo-water-return-line/
Do you have a link to the kit you bought?
I don't have anything helpful to contribute other than suggesting to make sure that you do it right. It's a pain now, but it will be even more of a pain down the line if you have to fix it again. I've been ignoring a small leak on that return line fitting in my car. Still weighing up what to do with it.
Jonny @Dose Pipe Sutututu has routed it back to the front of the engine to make it less painful. See this and following comments in his build thread. Not sure how it has been holding up since though.
I've driven it around "in da hooodd" and it seems ok, have driven it around with the A/C on as well to generate more heat. So far no leaks.
Yet to do a long drive OR a track day in it, so both will be the tests.
I think if I were to do it again, I would just plumb the water return straight into the intake manifold's bleed ports (un-used) on the top side, noting that I have an aftermarket one.
I hope this works well, because I cannot be fked working on the car ever again :D
In terms of your usual highflow kit, I would just return the water to the hardline behind the head.
  • Like 1
It is possible to connect to that hose without removing the valve cover or inlet plenum, but it is tricky. I have the water line I made for my ATR43 hooked up there. You might find that the old hose is perished and gets damaged during install, so it may be prudent to get a replacement before you fiddle with it. I cut out the 90 degree portion of a universal z hose (Gates part number 01-0002) to replace mine.
Thanks for the tips. I was able to get it in but got cut up by the brake line retainers. lol. Got at ATR43SS-2 and its tight in there. I bought a Mamba GT30 oil/water line kit, turbo outlet studs, turbo to manifold studs and exhaust manifold studs. Shipping was quick from Taiwan to Hawaii and quality is good. I needed to trim the lower right turbo to manifold stud and grind the turbine housing a bit to fit the bolt and tool. When installing banjo and lines to turbo, I needed to tighten line on bajo first and then install onto turbo, because theres no way to fit a 19mm wrench to install the lines onto turbo. Now, I need to find a fabricator or fabricate my own 4 inch turbo inlet pipe.
  • Like 1
Yeah it is very tight getting the lines into some cores and I'm not surprised a generic kit doesn't always fit perfectly since depending on turbo and manifold combinations. In my case I used an AN extension which I had to bolt on before installing the turbo and then changed one of the hose ends from straight to 45o to keep the line away from the compressor cover.
You really should either head sleeve or replace the rubber oil return too, it won't last long with all the heat down there
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
