19 hours ago, The Bogan said:
I assume some busted arse rusty one may be getting a new lease of life
Are the chassis numbers stamped on the JDM/AUD models? Or just the riveted on plate?
stamped onto the firewall iirc.
Edited by defari
Could just add material, grind down and use something like this.
Lol... Or just drill out, reweld on another firewall, maybe from another GT-R or a GTS-4, Gracer vibes lolololol.
This happens more than people know, there's lots of money to be made rebirthing cars
Lots of rusted hulk or crashed "collectable" cars are "refreshed" this way
Meh, once you swap all the JDM parts onto a ADM shell you wouldn't really notice
Whilst there was a few things that the ADM required for compliance here, it's all bolt on stuff really isn't it
The only tricky work would be the cut and shut on the firewall where the stamps are
The rest is basic nut, bolt, respray if you use a donor for the body numbers, block and other parts
  • Like 1
And some how fix the hole in the roof left by the aerial
People remove sunroofs and manage to make it look like it was never there, welding up a small hole in the roof is a simple job
The illegal rebirthing and stolen car parts industry is a real thing, from full body swaps to just swapping interiors, the other parts and panels are then sold on, just look at the steady supply of parts in the classifieds, and the "wanted to buy whole car" adds from some wreckers where they advertise they will buy wrecked or damaged high end cars
Hell, when I was thinking about getting a new Coulson style interior for the SS I replied to add in the classifieds for a full interior, I turned up at a joint in the industrial area of Ingleburn, it was full of stripped and chopped up JDM and Commodores, the shady looking characters were more interested in what was under the bonnet of my car and where I lived than actually selling me the "full Coulson" interior that was in their warehouse area that was full of stripped car parts, my spider senses tingled and I got hell out of there
High end, high demand cars and parts shopping lists for crime is a real thing, it a profitable business, these thieves aren't stealing cars for joy rides
Fun fact about some stolen cars: Western Sydney crime gangs, and other hard core crime areas, are holding stolen "kill cars" that they use when the shoot each other up, and every second top tier gang member has some form of 1000hp mint nut and bolt "resto" classic, JDM, ADM or Euro thing parked up
  • Like 1
Wanna know one of the huge dollar stolen parts rings running around at the moment?
LDV vehicles! So hard to get parts for an LDV the crooks have figured it out, steal them, strip them, and are making bank, as lots of places now have LDVs and they want them fixed!
Hopefully it's just one of the early nails in the coffin of those horrendous shitboxen.
I was hoping Australians utter hatred for cheap Chinese shit would do it.
But our love for outright cheap shit keeps winning.
But yes, them, MGs etc, they're so woefully built, with such low quality stuff on them. Even things like how the crash bars are welded in isn't right. Like Blind Freddy would lay a better, more accurate weld!
But people are lapping that shit up. :(
It really shows, you truly can produce utter shit, and as long as it kind of performs the functions, people will buy it!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
