Hi Sau community,
I have a mint S1.5 Gunmetal Grey R33 gtst coupe, blueprinted motor, forged pistons, metal head gasket apart from a boost controller, spitfire coilpacks, turbo timer and 2.5inch exhaust with Cat  it's stock.
Looking at advice on a series of upgrades.
Would really appreciate input regarding Haltec Elite, Greddy Plentum,Fuel Rail, Blitz Front mount intercooler, Tein Coilovers and best slotted discs.
Cheers 🥂 Dan
  • Like 1
https://www.sau.com.au/forums/topic/485878-new-member-adl-r33-gtst-s15-rb25t/
Welcome Dan
As you didn't mention the stock turbo, you should probably add a high flow standard turbo to your list and remove plenum and fuel rail as they are not required for a long time.
Yeah I was going to comment on this. Somewhat _unusual_ to have a built, blueprinted motor when everything else is stock?
Nevertheless, the age old wisdom applies: What is your goal for the car? Be honest, and then you later find out what you need. The recipe in the other direction is sadness.
The path is not necessarily "Buy shopping list, car become more fun"
Yeah, "blueprinted" does not mean "built" (in the common usage of "built" where that means "built tough with forgies and so on"). Blueprinted just means that when it was assembled the bearing clearances and other tolerances were all made to be right in the middle of the range given in the engine manual. Or otherwise to some exact specific value liked/used by the builder or someone else with good knowledge on the best setup.
It is a term that I haven't really heard used by anyone since I stopped reading Street Machine about a million years ago.
  • Thanks 1
Yea, it's also so they can be written down and referenced (and reproduced, really).
My old forged motor was blueprinted... but also funny that a car would exist with a forged motor and nothing else. Entirely possible that a R33 GTST lived its life unmodified and eventually had an engine failure.... but most don't go that way and go down in fiery glory via a little extra air going into them :p
It's still a common term, in specific areas. Things like go kart engines, builders will talk about blueprinting, which is pretty much as above, where it's just built to the absolute best tolerance to extract that last poofteenth of a horsepower, in a heavily restricted engine build series.
I've heard the term from motorbike racers too, especially 2 stroke, that seems to be the main group still using it really is 2 stroke engine guys :/
8 hours ago, Duncan said:
Welcome Dan
Thanks Duncan,
Bought it in 2008 had some major engine issue, Had RPM in ADL build it to apparently handle up to 400kW, After having the engine rebuilt for $10.5k and a respray for $6k spent more on it than a 33 was worth at the time. Been sitting for 2 years. Goes well but can never have 'too much' power. Just looking at where to start. Do you have any recommendations? High Flow turbo's from Hypergear seem cheap at 1k.?
  • Like 1
Yeah, short story is I had children and didn't have enough disposable income to complete the upgrades. I want to drive it on the road but to also keep up with my mates e92M3 at the bend motorsport park.
  • Like 1
Welcome.
The older I get, the more I prescribed to spend once, spend right.
(Or, poor man pays twice).
If you have a final vision in your head of what you want, try to work toward that straight off.
Hi-flow turbo would be nice, but if it won't suit your final goal, it may be a waste of funds that could go towards what you truly want.
I hope you can get it to that point one day.
Also, pics please 🙏
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
