These are marketed for shops over here in North America. They're called "Bag in a box" oil.
It's not very popular as most shops just stick to barrels and metered oil guns. I've never seen these used or sold for at home use, although the one in the video does seem a tad smaller.
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994309
53 minutes ago, Duncan said:
Hard plastic can be recycled, foil can't right? Can't see how this is a step foward.
Yeah, but I reckon the number (fraction?) of oil containers that actually get recycled would be pretty small. They are, after all, at least contaminated with clean oil, more likely contaminated with dirty oil. And if they go to an oil recycling depot of some sort to be emptied into the big tanks....I'd put coin on the probability that they just get pitched into the bin at that point. Even though we're talking about a "recycling facility".... have you seen the sort of oiks that work in places like that? Unlikely to be thinking about the prospect of recycling the bottles too.
  • Haha 1
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994317
On 10/23/2024 at 1:43 AM, PranK said:
Has anybody seen these in Aus? What a concept!
These are sold all the time at Walmart and like others have said the angle is "more eco friendly". It is slightly cheaper. Oil-contaminated plastics cannot be recycled so less of it is better, but you need a whole bunch of extra stuff to handle this. You need probably one clean 5 quart oil jug you set aside to use as an intermediate holding tank. You need your local hazmat to return your oil catch pan AND you need to make sure whatever oil catch pan you use can hold engine oil without any risk of leaking during transport. Or you have dedicated used engine oil containers that your local curbside recycling will drain and return. Personally I have stuck to just buying 5 quart bottles because this is just too much mess to be worth the hassle.
  • Like 1
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994341
Some good points there @joshuaho96
I think I just looked at the box and the tap and started thinking of how much cleaner my changes could be. 🤩
I mean, I could always just use a funnel...
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994343
Seems like thats the case here also. :(
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994344
I'll stick with the plastic containers, as stated by others, as it's where the old oil goes, I then just drop them off at SuperCheap, who apparently recycle it, or something....
I believe this makes Captain Planet not so angry with me for owning a infernal combustion engine, although he is still pretty pissed at me for using old engine oil to stabilise dirt pads in old workshop and factory yard hard stands in the pre 1980's
There was nothing better than some old engine oil to strengthen and waterproof a dirt/gravel patch pad back then, and the rainbows that flowed off the pad and down the storm water drains when it rained was very pretty looking, I believe that practice is frowned upon nowadays 🤔
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994345
I buy oil buy the 10L drum.
It's a square drum. Comes with a tap. Works the same way as above, but normally more economical to buy per litre.
However, you need an intermediate dirty oil drum for your first change, as chances are, your car doesn't need 10L in it.
The cruiser is great for using the drum. It from memory is 9.3L of oil to fill. And it gives no f**ks if you give it an extra 700ml, and bam, you've got an empty 10L drum ;)
Oh and then on top of that, I've normally got a 20L empty drum around that I tip used oil into from smaller dump outs if I do t have an empty 10L.
A few weeks back I dropped to the tip about 150L of used oil.
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994347
Have seen for sale, but not in person.
From memory penrite use them, for sale through at least repco.
But, as discussed here, for the home person, a container to put the used oil back into is helpful.
And for a work shop, they normally buy in larger quantities than these.
I'm guessing it's just cheaper to make and getting better profits for the company.
https://www.sau.com.au/forums/topic/485895-boxes-of-oil/#findComment-7994453
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
