So i got a 97 stagea with rb25 and it’s having issues running it starts runs for a good 10 or so seconds than shuts down used to run horrible for a few seconds till i cleaned what i believe is the IACV now it runs healthier but still shuts down previous owner ran the fuel filter backwards before realizing than putting it the right way. Cam angle sensor was replaced aswell some things are unplugged under the dash and i have no clue where they go cause previous owner did some uhhh funny wiring theres also a random plug in the engine bay where i have no clue where it’s home is lol. Vacuum is good and spark is good even when running so i’m at a loss previous owner also ran regular and i was told it needs at least premium. I guess i’m kinda lookin for some tips on other things to check i probably left out a few things i checked. Thank you all
https://www.sau.com.au/forums/topic/485897-rb25-starts-but-wont-run/
Hi and welcome to :sau: !
I'd be taking some pics of the plugs and wiring you've found and posting them up. The guru's on here will be able to get more from those than your descriptions of them. :)
I will try to get some pics today if i remember haha how would i go about putting them on here is there a way to do it from a phone it says i need a link? Thank you!
With the idle, have you reset the base idle screw with the IACV unplugged?
Very likely the base idle is set far too low. 10 seconds sounds about right for the ECU keeping the IACV open at about 1000rpm, then it should settle for about 650-750rpm (I can't remember the exact rpm point). If the base idle is too low, it can cause the car to stall.
I believe so haha don’t quote me on it my old shop foreman is helping me out. I also totally forgot to mention cause i’m a dumb dumb when you even try to give any throttle it chokes it out quicker if that’s any help. I gave the MAF a clean really wasn’t that dirty. He recommended i check the o2 sensor one day idk if that will have any effect?
56 minutes ago, PranK said:
Just click/tap the link at the bottom of the editor that says 'choose files'.
Here's some photos of wiring i cannot find the homes for the first one i didn't realize till after has a few more hidden behind them so there's a couple more but that's what i could find. Thank you!
I'd try to send the video of it running but idk if that's possible? Sorry I'm very new to this i usually work on old american cars so this is all very new to me lol
I don't even know is those worked i can no longer see them
Those didn't work. Depending on if you're on a phone or PC, you can click the add files button, select each photo one at a time (pick one photo, tell it to upload, click 'add files' again.)
It sounds like a few things are unplugged, one is possibly the AFM (or wrong AFM) or the TPS.
I've had the same issue before too leaving the temp coolant sensor unplugged, but that only became an issue once the car got hot.
To know what the base idle is doing, unplug the IACV (electric plug to it), and see if it'll start up, and what the idle tries to sit at. It will be interesting if it can even start with the IACV unplug, and that would be a big clue too if the idle screw is set too low.
Will wait for the pictures to load again so we can check plugs.
It does start with it unplugged it ran a lot healthier after i cleaned it out a bit it still kinda idles rough sometimes and shuts down quicker but when it sounds healthier it runs longer but even when you attempt any throttle it like instantly chokes it out and the car is like NOPE no throttle for you lol. also only options i have to put photos are to only use links or URL and that is what i did and i could see the photos till it refreshed and now i can't see them lol
1 hour ago, GTSBoy said:
You can't post images until you have like 10 posts or something.
My apologies @Harley80 I forgot about what @GTSBoysaid. I have fixed this for your account now so you can upload images.
  • Like 1
  • Haha 1
Oh hahaha i thought i was missin something lol
Here’s a video of what it’s doing excuse my finger we lost that plug when i took the video but found it yesterday. That’s when it sounds a lot healthier sometimes is really struggles to idle and chugs still it shuts down
Edited by Harley80
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
