So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.
I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan.
So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea.
The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit.
So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent.
The price difference between the 300 and 400hp models seems a bit crazy.
Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k
From my limited research it seems that the only differences are that the 400r/Red
  1. Red runs more boost and a more aggressive tune.
  2. There are are turbine speed sensors on the turbos.
  3. Has 2 pumps for the water to air intercooler.
  4. Runs an engine oil cooler.
I'm guessing that the exterior trims might look a little more sporty as well.
I had a lazy look for upgrades to bridge the gap on z1motorsports
They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD.
Personally I would rather get the car tuned on a dyno which would probably add more cost
Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750
So the total cost could be around $5100
So for easy number 5k + 27K = 32k
I guess that would leave some change left over to swap out the open diff and fit a LSD
Any thoughts?
  • Like 1
I reckon you are 100% right on the money.
The only reason I bought Red Sport instead of the base VR30 is that I am investigating racing it in Production Cars, and they require you to run a (mostly) standard car....therefore knowing exactly what was in the RS spec was important to me and I paid the extra.
Other than that, for sure I would have pocketed the $10k and spent them on mods instead. Plus the non-RS models are more likely to have had a nicer life prior. Just a warning though, mods always cost twice as much as they look like they will on paper :)
BTW you should also consider the 400R imports, they are about the same price as a local RS but 5+ years newer. Of course that comes with the usual warnings about finding parts, unhelpful nissan dealers and finding insurance
  • Like 1
Yeah I would like to try and get a ADM car to reduce issues with insurance.
I've decided if I end up getting this car I will set it up to be a sleeper build, leave it looking stock/dad spec on the outside
I wonder if you can just drop in the 400r/Red/Z ECU or better still use a flashing tool to copy the map off one. Backup the factory map and then flash the 400hp cars onto the 300hp cars ECU?
Also I'm a little turned off by the engine being only direct injected. If you put a catch can on early enough this should save all the build up on the valves and intake ports ?
Edited by 180 wanabe
So these motors don't seem to have as big issues with DI port carbon as others do.
I also had a good run with my VK45DD cima, it did develop a light missfire at idle at around 300,000klm so I started using the subaru upper engine cleaner with each oil change and it improved (still happened occasionally)
So, my plan with this car is to add a catch can, do upper engine cleaner with every second service (ie every 10,000klm) and see how that goes, I'll pull the intake off sooner or later and have a look at the valves too.
On the ECU, you need an Ecutek tune; the Redsport ECU will expect sensors (turbo speed) and the 2nd water pump that the base model doesn't have...but I'd expect a tune (mostly more boost) is all you need to get there.
1 hour ago, 180 wanabe said:
Pretty sure that the Ecutek can also tune the TCM for quicker gear changes as well :7_sweat_smile:
Apparently announced on Instagram just this week; I can't access it and nothing on their website
Their GTR TCM information is here: https://ecutek.zendesk.com/hc/en-gb/articles/360001830657-Tuning-Your-TCM
  • Like 1
Think I found another reason to buy the Q50 rather than the skyline import, seems that unless you get the 400r the other models such as the GT miss out on the decent brakes and don't have the flappy paddles on the steering wheel to change gears.
Its my day off work today and the Q50 listed @ the dealer in Brisbane that I mentioned in my 1st post looks like it sold as its listed as no longer available... Would have checked it out but can understand why it sold as it was a bargain price.
from what i was told alot of options you can choose to get from the factory when buying a new Q50 you get standard with a Redsport or 400R.
Paddle shifters and so on plus the sports+ mode isnt on all standard Q50's im sure the wheels look different plus the 400R kit looks the best next to the LBWLK kit.
im sure there is alot more things that are different and im sure mine has LSD standard rear.
im sure i was told suspension is different aswell and turbos.
so will this basically make the gearbox decent?
because it takes imo so long to shift gears and even drop back.
the response when you have it in manual mode is laot better but even the shift is like not instant will this change that?
6 hours ago, HYBRID VL said:
also the 400R will probley hold its value more but dont forget there is a Nismo model 400R aswell.
That might be so, but as per my rough calculations in my 1st post at the current time of typing this, buying the Q50s and fitting the upgrades still yields around a 13k difference. So even if the Infinity doesn't hold its value its going to be 10 to 13k cheaper upfront with better upgrades than the stock 400r.
This allows plenty of left over budget to fit a tranny cooler, LSD, catch can, heck even new turbos if the std ones shit themselves. Probably cheaper insurance as well.
I can only hope that either the 400rs drop 10k in price around the middle of next year "my investment loan comes off fixed interest and I will refinance with a bit extra to fund the new car" or I can find another stock Q50s with low kms for even less than the one I found a few days ago which seems to be the more economical option. I could always just debadge the Q50 and swap the front grill for a Nissan one and slap on a 400r badge on the back to have the best of both worlds haha
Not necessarily shift speed because that is most mechanical/hydraulic not electronic.
It should allow modification of shift up and down points and therefore stop the auto shifting when not wanted. On the dyno the other day it consistently changed by 6200 at full throttle 4th gear and the power curve was still rising
I spent a bit of time with the paddles on a long drive yesterday and found the opposite to you; mine shifts faster up full throttle in auto while the delay for the paddles requires some learning to plan ahead. It also has an annoying habit of changing back to auto from manual mode at partial throttle (it does hold manual shift with no throttle like long downhills thankfully). So, I'd say they are useful for being in the right gear when you leave a corner, but not much else.
Sorry for the off topic....for me the big difference between an infiniti and JDM import is you get a much newer car with the JDM option for the same price or cheaper than local cars
  • Like 1
im sure mine stays in gear and wont shift unless i shift it?
and for sure it wont go back to Auto mode if its put in manual mode?
if i use paddles but its still in D then of course it goes back to auto mode.
but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this.
it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D.
i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have.
Now local cars have kinda caught up even the lower models.
but yer transfer rates and other things makes it almost on par.
interesting....sounds like the later trans has software differences (or AM vs JDM).
If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open :(
So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars...
https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
