Hi all
my r34 has been off for over a year with occasional start. Today I noticed a lot of noise from engine bay when turning the wheel as if power steering has no fluid . Checked and loads of fluid had flowed out of the resorvoir. Has anything been blocked/ destroyed? Maybe fluid can’t get into pump
and flowing out ?
could it need bleeding by turning steering side to side?
thoughts?
https://www.sau.com.au/forums/topic/485922-r34-power-steering/
Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere?
You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat.
Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
Edited by Beanie
