I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
  • Like 1
  • Thanks 1
  • Haha 1
https://www.sau.com.au/forums/topic/485931-hello-everyone/
They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
https://www.sau.com.au/forums/topic/485931-hello-everyone/#findComment-7994822
Welcome.
Glad to hear that you have gained some knowledge that has helped you.
I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump.
If you get a chance, post pics of your car, please. 🙂
  • Like 1
https://www.sau.com.au/forums/topic/485931-hello-everyone/#findComment-7994828
  • 3 weeks later...
On 11/15/2024 at 12:26 AM, niZmO_Man said:
As above, can't rely on rubber belts too much when you're hitting OVER NINE THOUSAND !!!11!! revs, so electric conversion (Astra as mentioned above) is the way to go.
So....I managed to fix the belt coming off problem, but unfortunately i destroyed my oil pump. While testing and hitting my rev limiter a bunch, my oil pump took a shit. I actually heard it break. In my great wisdom i decided to hit redline 5 times (original plan). Lowered it to 7500 for the soft limiter. Normally it would come off on the first go. The 6th time I hit the limiter the pump broke and as i began accelerating again and hit it the 7th time, oil pressure dropped and the protection kicked in. It actually made a "tink" as if i dropped something hollow.
The motor is pulled and should be rebuilt and put back in 3 weeks. No bearings were spun and i could have gotten away with simply replacing the pump, but since i had to pull the motor....might as well build it
I made a billet tensioner and the belt stayed on without getting frayed. I also made one for a friends R33, but I was thinking of using a hydraulic unit to keep constant pressure on it when the belt stretches.
  • Like 2
https://www.sau.com.au/forums/topic/485931-hello-everyone/#findComment-7995460
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
