Anyone else have a grinding issue changing from 5th to 4th gear. I have no issues 3rd to 4th and 4th to 5th. But the car seems to grind a little when I do 5th to 4th …
is this a common issue? Had it from the last owner. Bit annoying as I can’t hard shift down. Feels like I have to push a little to the left to get it smoother into gear.
thanks
https://www.sau.com.au/forums/topic/485943-fourth-gear-grind/
thanks
Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this.
If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
  • Thanks 1
Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.
I should have said just change from 5th to 4th gear … down shift. There’s a grind.
I have a new clutch X clutch … but as I said all the changes in other gears are fine.
How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
Most likely the 4th gear synchros (and probably others) are worn. Redline lightweight shockproof gear oil has been the go to for masking that issue a bit, it is very common.
The only real solution is to fit the R33 series 3 gearbox bits in a full rebuild....or accept it is not a new car and shift slower
11 hours ago, GTSBoy said:
Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
I've worked around a crunchy/grindy gearbox for so long now that track instructors note how I have absolutely awful shifting habits. S L O W shifts and then blipping the throttle even on upshifts out of habit. My vote is R33 series 3 gearbox, those are still readily available and relatively cheap.
Edited by joshuaho96
The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes.
I don't have any problems with synchros or gear crunching.
  • 3 months later...
Did you manage to fix the problem? I’m having the same issue but everything is new in my gearbox
My fourth gear is not perfect but I hard shifted it into fourth from fifth and its shifting better now. Not bothering me atleast.
I think the cheapest option is to replace the whole transmission for a R33 heritage one for like 1500 USD not including the shipping. Thats what I was going to do but its not bothering me anymore. What is bothering me is my idle is weak now after I change my intake to a smaller one so I need a tune again - loves to stall in reverse and when the aircon is on lol ... Love these older cars. WOT is strong though.
10 minutes ago, joshuaho96 said:
Either you specced the wrong fluid or your clutch is not releasing properly for whatever reason.
I was told to put in vmx80 for about 500kms. Then change to Motul 75w90
it goes into all gears smoothly, I do hear a slight hissing noise when release clutch
Just the down shift from 5th to 4th is crunching
Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.
Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong
https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg
https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA
https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g
https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g
https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
Does your rb gearbox have the common input shaft bearing sound? (One one where it goes away when u push the clutch in or get to higher revs) I heard if you put the wrong oil it can get this sound.
Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related.
I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in.
Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout.
It won't matter either way, new box will mean this one can be relegated to the parts pile.
  • Like 1
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
