Hi Dose, I know you'll be reading this thread. Brake pads are going good mate thanks.
Anyway, pulled the 33 fuel tank out today because we were limited to a disgusting 480hp on the old fuel pump setup.
On pulling the tank, I found the cracks in the photo (I don't think they're leaking, but fuel evaporates quick so hard to tell).
What's the best way to repair, or is their a new tank alternative?
Thank you.
  • Like 1
https://www.sau.com.au/forums/topic/485974-r33-fuel-tank-crack/
I personally haven't been in this situation, however have repaired a cracked radiator using JB Weld and held up until I could replace it with a Honda Accord years ago.
Maybe @GTSBoy might have a sound strategy?
I'm not that familiar with R33 tanks. Plastic? Up behind the rear seat between the towers? Or under the boot floor like a normal car? It's the battery that's up between the towers isn't it?
So, plastic tanks. Well, um. The obvious reco is plastic welding, which you'd only look at asking someone who's really good at to contemplate trying. The fuel contamination and grot is probably going to make it quite difficult though.
Whether plastic or steel - the end of the crack will want to be drilled before any welding or sealing is done. Otherwise it will just continue to wander along until something bad happens.
Steel tank? The obvious answer is drain, wash, purge with inert gas and drill the crack end and weld/braze/silver solder/whatever the guys who do that to fuel tanks recommend.
I had a crack/hole/leak in the bottom of a Commodore tank (oe was it my ALFA? - can't remember) that I slammed some gorilla snot onto and it never leaked again. It worked surprisingly well.
Or, it's time to fab a new tank.
It is a very complicated plastic tank. Sitting between the rear seats and the rear subframe. Requires a siphon venturi pump in the hat to suck the fuel from the passenger side to the driver side of the tank. The answer is probably prepping the tank very carefully to eliminate all fuel fumes, drilling any cracks to stop propagation, then plastic weld. I don't really see any other solution here.
which is to say....can be done but probably a specialist thing.
My guess is the tank was dropped with the breather still connected at some stage, there's no reason it would crack on top of the tank on its own.
  • 3 weeks later...
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
