17 hours ago, Milkmun said:
S2000 is nice.
Absolutely agree. For similar reasons as @GTSBoy pointed out: long nose, short deck. 😍
But while production did start in 99, I don't see this as a "90s" car.
I wonder what your thoughts of a "long nose, short deck" are if that were said in a kiwi accent...
Depends on the part of NZ. No probs with a short duck. 🦆
18 minutes ago, GTSBoy said:
I think you might have skipped a whole vowel sounds there C.
I might have gone a little more South Efrican.
But this is off topic.
😍😍 FD 😍😍
  • Haha 1
14 hours ago, Milkmun said:
Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
I'm lucky enough to have one in the family. A bloody fun car to drive.
  • Like 1
On 19/12/2024 at 2:01 PM, Ozdavroz said:
FD is so sexy she can pull off tri-spokes
The VS Commodore was so sexy it could pull off the tri-spokes AND the novelty sized Supra style rear wing
  • Like 1
I was driving behind an FG (or something similar) Falcon ute with a shopping trolley wing (1/3 the height of that ^ one) on the back end of the hard cover....and it took me 5s to realise I wasn't looking at an NSX. f**king bogans.
  • Haha 2
They do look similar
  • Like 1
  • Haha 1
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
