I'm looking for a direct bolt on turbo upgrade for my 93 R33 GTST.  Anyone have experience with this Greddy T620Z turbo upgrade? I'd like to be able to run about 300hp to the rear wheels without putting too much strain on the turbo. I do daily drive the car.  Pretty stock car with basic bolt ons (exhaust outlet, down pipe, high flow cat and catback exhaust along with intake and FMIC).  I'l probably have a Haltech plug n play on the car before installing the turbo.
https://www.greddy.com/products/turbo-upgrade-ecr33-er34-t620z-rb25-11520057
Also, any thought on this much boost on a 30 year old motor with 250,000KMs?  Engine feels/sounds strong for what it's worth.
Thanks you in advance!
A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.
If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/
If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.
If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.
No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
  • Like 1
300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish).
If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile :)
  • Like 1
Wasn't there some discussion of how the Hypergear high flow actually has different dimensions so it's not a true bolt-on replacement? Honestly if that's the case I would consider just going true twin scroll and go down a massive rabbit hole of getting all that to package as close to stock as possible.
Yeah - the Hitachi core is huge (long) and the core Tao uses is quite short, so the compressor housing moves backwards.
But I wouldn't let that stop me. In fact, I didn't.
But I imagine that the correct thing to do is to go for the latest G series on an Artec manifold. In V band. And f**k the twin scroll, because short short Artec manifold runners + easy install/removal/adjustment outweigh the small loss in spool.
Yeah, but twin scroll is the OEM thing and I love pain.
11 hours ago, GTSBoy said:
There's no twin scroll on the OEM turbos. On the manifold, kinda, yes. Not on the turbos.
Rather it's the OEM thing these days. I don't think I see single turbo monoscroll on any I6. Obviously back then twin scroll turbos weren't readily available so I saw a lot of "twin entry" designs which had a divider on the manifold but nothing on the turbo.
And that alone was a huge improvement to single merge collector.
Those early "experts", used to grind down the divider for "flow" and lost response.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
