Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.
if it’s an n1 or something very limited then maybe care more about it’s heritage
Buy someone else's modified car. It'll be risky - but so is modifying it yourself.
People with Modified cars are often ready to sell. Find a nice sorted one, pocket the difference.
  • Like 1
On 12/23/2024 at 12:05 PM, GTSBoy said:
It will blow out fast.
$3k for turbo, could easily be a bit more.
$2k for manifold, at the lower end, and therefore likely to be more.
$1k for dump, could easily be more.
$1k for coating these things, really should be done.
$1k for desirable extras, like EGT ports, EMP ports, heat shielding. Hell, probably more like $2k.
You get close to $10k just for the main parts, without pipework fab, gaskets, fasteners, labour.
$15k is rock bottom. If you need intercooler, fuel system, clutch, ECU, you're pushing $30k. It is just too easy to spend money.
Sheesh, isn't that the price of a full engine rebuild almost?
It’s almost the price of an engine build, you won’t have anything to bolt onto it though
  • Like 1
It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work.
As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
  • Like 1
20 hours ago, joshuaho96 said:
FWIW a lot of the local owners that do a medium to big builds tend to have cars that are perpetually broken.
Common theme, also FYP
If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau
GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.
Some items that will save you money
- plug in link ecu g4x is much cheaper than haltech.
-Pulsar turbo, seem to be "OK" now, never used one myself
You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.
Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
-9s are discontinued supposedly. But you can still get Nismo R3 turbos which are something like a -7 but subtly different? -7s are also available. HKS GTIII-SS and GTIII-2530 are also available but they're journal bearing MHI turbos.
Depending on conversion rates and when you factor in Australian David Jones pricing on fabrication these days, this kit (bolt on affair, zero fab) nearly seems worth every dollar.
https://www.spectrummotorsportssolutions.com/products/copy-of-gt-r-rb26-single-turbocharger-kit
Their disclaimer:
**Please note - While this kit includes everything needed to convert to Single Turbo without additional Fabrication, Professional installation is suggested. The PS reservoir will need to be moved from the stock location, however everything else fits R32/33/34 GTR w/ OEM AC and Power Steering Pump**.
1 minute ago, MBS206 said:
And I'd be astonished if a bolt on kit truly were bolt straight on, hence I bet the recommendation for a pro to install it.
The quality of car enthusiasts these days, need I say more?
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
    • A few more recent pics
