Purchased a NC MX5 a while ago
Basic suspension mods done, BC coils and Whiteline sway bars
New DBA calipers, discs and pads
Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's
Added some typical NA bolt on's, i.e. full exhaust and intake
Added 0.5ltrs with a MZR2.5 swap, nice bump in torques
Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street
The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising
But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot
Why is dose so appealing
All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
  • Like 6
  • Haha 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/
Turbo gods, some assistance and recommendations please
I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013
Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit
Max RPM on the 2.5 is around 6500rpm
The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing
It comes with either a 0.64 or 0.86
From my understanding, which so far is based off googling, so make of that what you will
0.64:
spools faster = good
Makes more EGT heat on boost = bad
Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions
0.86:
Spools a "little" slower = how much slower??? remembering 6500 is my max rpm
Makes less EGT heat = good
Makes a little more power up top = again, power goals is only around 200
Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises
I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well
Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996089
This should be pretty easy.
200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo.
These things have like a .48 rear.
You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
  • Thanks 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996093
No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit.
However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter.
Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes).
If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
  • Thanks 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996096
0.64:
0.86:
STOP GOOGLING
FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758.
DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW.
IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
  • Like 3
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996101
2 minutes ago, Kinkstaah said:
STOP GOOGLING
I somehow quoted my post instead of editing it. I regret nothing.
  • Haha 3
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996102
I know you don't want to hear this comment, but I can't not say it.
I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.
My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.
Now you have a NC that will try to kill you from time to time and will be exciting to drive :)
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996106
This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about
The whole reason is "Just because fun", and "Just because fun" is what I do
And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give
My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea
So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍
The only real racing I do nowadays is to the toilet
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996108
8 hours ago, Kinkstaah said:
STOP GOOGLING
And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning)
Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give
My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996109
PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger
Both are -50*67mm 8 blade billet compressor wheel
Cheers
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996110
Cheers
What kind of power delivery are you after?
If it's nice and linear, the 0.86 would be better. If you're after bake tyres and head snaps on boost the 0.64 would be fun.
I'm boring and old, so linear power is preferred.
Lately I've been watching videos on Z06 Corvettes and super charged Mustangs....
  • Thanks 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996112
Cheers for the info mate, I'm old too, 60 years old next May, so a more linear delivery of the 0.86 would be better as baking tyres and snapping heads isn't on the cards for me or the car
I assume a more linear power delivery would be better for engine and drivetrain reliability as well, IRT the torque load at lower RPM???, as well as lower EGT's???, if my understanding of that is correct, have I got that right???
I've only got a really basic understanding of turbo sizing and all there characteristics
Cheers for the useful information
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996113
Nah nah nah nah. Don't do it.
It's not all about the full throttle power delivery. The main "street fun" and drivability gains from smaller rear (in this case) is how you will have boost available from a low rpm when yo just roll onto the throttle. Think jinking in and out of traffic, coming out of roundabouts, etc etc, where you just want to roll onto the throttle a little and have the spooly noise from ~2000rpm and a swell of torque. More of what you've already achieved by going to 2.5.
And then, towards the tail end of 2025 you can pull the turbo 4 out and put in a V8 like we originally suggested. :P
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/#findComment-7996114
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
