Sorry to hijack this thread, but if you do decide to go for a mech diff, or anyone else out there has an acceptable condition stock diff they would like to get rid of I would be very interested.
As a bit of a background, my diff has a very unpleasant whine which has been diagnosed as a crown wheel and pinion which needs replacing. Will be $250 to fit which is fair enough but Nissan have requested an arm in advance and a leg on pickup to supply me with these parts new.
Therefore, if anyone has access to these parts or has an entire stock diff they would like to sell please PM me as i would be very interested.
someone said mech diff wont work with ABS... is it true?
Also anyone heard of Kazaa diff (local)? They cclaim to be quiet and u can retain ur stock diff casing just swap d internals
My mechanical worked fine with ABS. You might have a problem if you change the whole diff casing with one from a car without ABS as the sensor for 3 channel ABS is at the diff.
The amount of clunking you get is controlled by how tight the diff is, a mechanical diff *only* locks under power so if you stay off the accelerator it doesnt clunk, that can make it easier to live with day to day.
And finally you can and should just swap the diff centre, much easier.
Dunca, is there a certain type of diff that is easier to live off on daily basis,
e.g. 2 way versus 1.5 way versus 1 way? Or is it just a matter of staying on/off accelerator no matter what diff type above?
Also gts-t vspec, how's that Kazaa diff center going and how long ur mate has it? I wonder how these local products compared to things like cusco. Price i believe is much cheaper and quite tempting.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
