Hi guys,
I have a R33 that I'm redoing the fuel system on.
Currently it had a hack job by a tune shop that they have cable tied the braided lines under the car and jerry rigged a stock hanger to use two pumps.
I've redone the fuel tank with a frenchy performance twin pump setup, have ordered custom brackets for the fuel lines.
My question;
I am running AN8 feed and AN6 return.
On the fuel rail is it normal to have an8 fitting on one side and the an6 on the other?
I also noticed my ethanol sensor on the return is only 5/16 instead of AN6, should I look at running it parallel or it won't be an issue?
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/
Put the FPR, after the fuel rail but before the Y split.
If not, fuel will find the path of least resistance and bypass the FPR.
Another option is, new 8AN feed, then use both the original feed/return as dual return (that's what I did).
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996191
Makes sense, just not sure how to put the ethanol sensor in parallel after the fpr.
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996206
You could do it underneath the car (I personally don't like this ideal).
Mine is in the boot, but it's also on the pressure side from the main tank to the surge tank.
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996207
I just saw one of these bad boys: https://www.radiumauto.com/Split-Flow-Flex-Fuel-Sensor-Adapter-P2194.aspx
Looks to be perfect solution.
  • Like 2
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996208
Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix
Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.
Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
Edited by TurboTapin
  • Thanks 1
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996728
I was actually being a tightarse at the time LOL...
My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996742
My first thought is run hardlines, but running a soft pipe is easier and quicker, though normally more exxy...
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996747
1 hour ago, GTSBoy said:
Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it ;)
https://www.sau.com.au/forums/topic/486015-r33-fuel-setup/#findComment-7996784
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
