Considering the price of GTR stuff now the answer is yes. That's a straight forward TIG or even MIG job. I'd put extra tubing inside, for extra strength and weld it up. Then use the spare seat as an example to get the bolster rails in the correct position and the re-apolster.
If you don't mind me asking what did you pay for the pair as they are?
Yes, as above. The welding is an easy enough job.
Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate.
I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
  • Like 1
I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha
and paid $400
also included a photo of the passenger seat! She is mint
Edited by 32pwwr
Yep that's a superb price and ther is no way you will over capitalise on you investment.
As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
Those brackets are known for snapping.
Easy to fix the metal, and a good seat reupholsterer can fix the rest.
I'd potentially get them to look at making new foam too. Even if you've got the old, it will be partly compressed / not as supportive as it should be.
What do you think it would cost to reupholster? definitely worth saving regardless, especially how much I paid haha
will probably also look at welding a metal plate into the bracket for reinforcement.
Edited by 32pwwr
Will definitely ask, I’m expecting that I’ll need to sell my left nut
Update:
pulled the passenger bracket off and looks some what universal.
the driver bracket is proper cooked and don’t see how I could get it fixed.
my thought process is, buy a cheap passenger seat and swap the bracket over and foams as mine are cooked
Edited by 32pwwr
Just remake the bracket. It's just bent steel with a nut welded to it.
It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places.
The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
I sent off a message to a guy, waiting for his response if he can do it or knows someone.
How much is it to re-uploster?
Well that's a "how longs a piece of string?" question !
And I answer thusly: "twice half its length! " . . . . . .
Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !
Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
Edited by PLYNX
For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work.
Like everything, there is upholsterers, and then there is upholsterers.
Some really great upholsterers for automotive restos won't even appear to have an online presence.
My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats :)
On 1/4/2025 at 5:08 PM, The Bogan said:
Might be tricky matching the seat trim material
If your got the funds you "may" want to get the rear re-trimed as well to match the front
Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
