Considering the price of GTR stuff now the answer is yes. That's a straight forward TIG or even MIG job. I'd put extra tubing inside, for extra strength and weld it up. Then use the spare seat as an example to get the bolster rails in the correct position and the re-apolster.
If you don't mind me asking what did you pay for the pair as they are?
Yes, as above. The welding is an easy enough job.
Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate.
I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
  • Like 1
I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha
and paid $400
also included a photo of the passenger seat! She is mint
Edited by 32pwwr
Yep that's a superb price and ther is no way you will over capitalise on you investment.
As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
Those brackets are known for snapping.
Easy to fix the metal, and a good seat reupholsterer can fix the rest.
I'd potentially get them to look at making new foam too. Even if you've got the old, it will be partly compressed / not as supportive as it should be.
What do you think it would cost to reupholster? definitely worth saving regardless, especially how much I paid haha
will probably also look at welding a metal plate into the bracket for reinforcement.
Edited by 32pwwr
Will definitely ask, I’m expecting that I’ll need to sell my left nut
Update:
pulled the passenger bracket off and looks some what universal.
the driver bracket is proper cooked and don’t see how I could get it fixed.
my thought process is, buy a cheap passenger seat and swap the bracket over and foams as mine are cooked
Edited by 32pwwr
Just remake the bracket. It's just bent steel with a nut welded to it.
It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places.
The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
I sent off a message to a guy, waiting for his response if he can do it or knows someone.
How much is it to re-uploster?
Well that's a "how longs a piece of string?" question !
And I answer thusly: "twice half its length! " . . . . . .
Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !
Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
Edited by PLYNX
For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work.
Like everything, there is upholsterers, and then there is upholsterers.
Some really great upholsterers for automotive restos won't even appear to have an online presence.
My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats :)
On 1/4/2025 at 5:08 PM, The Bogan said:
Might be tricky matching the seat trim material
If your got the funds you "may" want to get the rear re-trimed as well to match the front
Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
