Wiring high beams in IC7 for R32 GTR
If that was the case I suppose you could call it "Mein's" brand.... ... I'll see myself out... 😅
with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled. I have already cleaned it a week ago. I unplugged the O2 sensor from the left side of the vehicle, and the car was still running. I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not. It cranks but doesn't start after engine temp gets up to normal range. I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
fair call about sau.com.au really, only the pics give it away
