I wouldn't think it would be all that hard. Any decent body shop would be able to do it for you.
What kind of kit are you thinking of getting?? I am looking for a decent kit for my R34, but have yet to find one. The Do-Luck kits are so-so, and I don't know whether Veilside make one for the R34 GTT. Anyone??
bonnet is the same length. the guard is wider. front bumper and rear bumper supports are different. you'll probably need to get adapters made to fit a larger/wider bumper. maybe $100 for all the adapters. also the sideskirts mount differently to the guards on a GT? compared to a GTR, so you'll have to come up with some clever way of makin those fit.
maybe GTR front guard, r34 gtr front fenders and keep the rest as gt and get the standard kit.
yes, but if you are putting a GTR front bumper on the car then the shortened GTR bonnet is rectified innit?
OK dimensionally the GTR bonnet is shorter... but I think it should fit into where a GTt bonnet goes properly as long as you put a GTR bumper on as well to cover the gap... that's what I mean...
yeah you need to break out the angle grinder on that thing...chopskies!!!Not that I've looked into it or anything :)
Either way the GT-t bonnet needs to be modded a little bit. And the GTR front spoiler needs to have some slight "massaging" to get it on without that bulged look from the sides being pinned in.
Okay, so im just going to put a GTR bonnet on it, front fenders, front bar.. it will all work out, the side skirts will be fine, the only thing now is the rear bar, as teh rear flares on the GTR i think the bar will need to be remoulded and pushed in at the tips....
thanks for your help guys :P
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
