F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.
So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.
PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.
image.thumb.png.179f31ce1857ae3d33efd93ca5d3c78b.png image.thumb.png.734c6623fe03e417ebafed5b9981a7ca.png
https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
AA8B4AA5-CF24-4678-9E40-71ACD67AEBD0_1_102_o.thumb.jpeg.908b699f2602c03d8a3381b0c0cf0599.jpeg 03247480-F3CB-4267-9A12-CA5EEFD47170_1_102_o.thumb.jpeg.9a1bc99046db164d644ca7f409078b90.jpeg  6FB05C48-090A-49A4-BB6F-CB64C51640D7_1_102_o.thumb.jpeg.d73b1a32bbde3119e47ad920cf14d0ef.jpeg
  • Sad 1
https://www.sau.com.au/forums/topic/486209-magnetic-drain-plug-snapped-in-half/
If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
:D
  • Haha 3
I'll update you guys when i get home from work, im going to try to fish it out.
I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
Just get the magnet out... I can think of 37 different options to get it out without removing the pan. 4-5x of those options are already mentioned here.
I personally would drill a larger hole in the pan, pull the magnet out and then block the hole with another magnet. Then reuse another magnetic oil plug. The more magnets the better.
Edited by TurboTapin
  • Haha 1
Are you trolling me
Are you trolling me
Yes and no. My second sentence is trolling but being that you're also from North America, I was really hoping you would catch onto my ICP reference. Then again, I'm probably one of the only idiots who listened to ICP when I was younger.
Jokes aside, if the magnet went in through the drain hole, then I'm sure you can get it out by there. Try some of the options the others have listed.
6 hours ago, kevboost7 said:
.....is it even possible to drop the oil pan without taking out the motor?
not really....in that it is possible but it would be easier to pull the motor than to take the sump off in the car.  It's not just that the diff is attached because you remove the axles and driveshaft, but you have to remove the whole subframe to get it out which is a heap of work including brake calipers and steering rack disconnected, have to support the engine from above because the engine mounts to the subframe etc etc
  • Sad 1
If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump?
The answer to the above is the same answer towards if I'd have any level of comfort leaving it...
Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way.
Use the methods in here. It fit in through the plug hole, it'll come out.
PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes...
Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
