R34 Manual conversion Speedometer
After throttle body? I’ve heard that you should not do that. Even if you look at the diagrams they show you that you should take boost from turbo.
What do you mean with ”hot side”? From what I’ve heard is that you should take it as close to the turbo as possible?
Like on the intercooler pipe between turbo and intercooler? Still weird why they don’t put an output on the turbo since you will need one. There is one for the RPM of the turbo.. are they doing this because they want you to take the boost reference from somewhere else except the turbo?
That wouldn’t work especially well? 🤔
