Hey all,
I just imported a second hand Apex'i N1 cat-back exhaust from Japan and was hit with horrendous importing costs as follows:
Australian Port Charge - $70.00
Delivery Order Fee - $45.00
Terminal Handling Fee - $15.00
Sea Cargo Automation - $15.00
Customs Clearance - $125.00
Government Duty - $96.62
GST on Importation - $37.20
Quarantine Fee - $97.00
Quarantine Lodgement Fee - $20.00
TOTAL 520.82 (plus 27.00 GST) - 547.82
Anyway, when i went to get it installed, i was told that charges should only be around 3% of the purchase price when it is second hand parts, plus possibly another 10% GST charge. Can anyone help me to find out if i've been ripped off or if this is all legit?
Cheers
Jason
https://www.sau.com.au/forums/topic/48651-importing-costs/
I have been told I will be hit with 34% for my car of the original purchase price but have not had that confirmed. I am expecting that anyway. A mate who imports has said it is 17% for bits but he was also the one who said 34% for the whole car so you are probably none the wiser from reading this!
https://www.sau.com.au/forums/topic/48651-importing-costs/#findComment-977078
The tag has something to do with it in some cases but not all. Something like an exhaust back box you would be hard pushed getting it through even if it was labelled as a gift without getting taxed.
https://www.sau.com.au/forums/topic/48651-importing-costs/#findComment-977898
sory about the timing but next time maybe try http://www.takakaira.com/ they're based in japan but are set up to send stuff anywhere, i havent used them yet but thats where ill be going to get some of my stuff. their prices are excellent too (this is not a paid endorcement :))
i noticed on their site they had about 4 different ways to send things so they could work it out to be the cheapest for you..
once again sorry about the timing, maybe next time :P
https://www.sau.com.au/forums/topic/48651-importing-costs/#findComment-981986
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
