its fitted to an s13.
It will fit many cars, some with a rear cover swap.
5bolt half shafts, 2bolt rear cover.
Having a look under your car should make it pretty clear.
The front 2 points that boltup at the nose of the diff may have rubber bushes on some stock units but this diff will still fit.
Rob
if the 32/33 in question has a 2bolt rear cover you should be able to swap it.
The rear subframes might even be the same on the r32 non turbo.
i think most 32/33's have 5bolt shafts, nearly all s13 are 6bolt.
The picture should make it clear as day to anybody thats interested, if your not sure send me a picture of the underside of your car and il tell you if it will fit.
cheers
rob
