rob9246 Posted August 12, 2004 Share Posted August 12, 2004 DIFF IS SOLD Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/ Share on other sites More sharing options...
adznight Posted August 12, 2004 Share Posted August 12, 2004 What model Skyline is it one at the moment, what models is it suited to? Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977501 Share on other sites More sharing options...
Adam 33 Posted August 12, 2004 Share Posted August 12, 2004 Im interested, can i come and have a look after work sometime? If so pm your phone number Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977512 Share on other sites More sharing options...
adznight Posted August 12, 2004 Share Posted August 12, 2004 Sorry my bad, didn't read. Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977523 Share on other sites More sharing options...
B-Man Posted August 12, 2004 Share Posted August 12, 2004 GTS-T or GTR diff ? Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977525 Share on other sites More sharing options...
Chris32 Posted August 12, 2004 Share Posted August 12, 2004 180 or S13 Slivia Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977534 Share on other sites More sharing options...
jaik Posted August 12, 2004 Share Posted August 12, 2004 Or 32 GTST ? JK Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-977870 Share on other sites More sharing options...
rob9246 Posted August 12, 2004 Author Share Posted August 12, 2004 its fitted to an s13. It will fit many cars, some with a rear cover swap. 5bolt half shafts, 2bolt rear cover. Having a look under your car should make it pretty clear. The front 2 points that boltup at the nose of the diff may have rubber bushes on some stock units but this diff will still fit. Rob Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-978374 Share on other sites More sharing options...
Nguyen Posted August 12, 2004 Share Posted August 12, 2004 pretty sure no s13 diff will fit an r32/r33 Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-978381 Share on other sites More sharing options...
rob9246 Posted August 12, 2004 Author Share Posted August 12, 2004 if the 32/33 in question has a 2bolt rear cover you should be able to swap it. The rear subframes might even be the same on the r32 non turbo. i think most 32/33's have 5bolt shafts, nearly all s13 are 6bolt. The picture should make it clear as day to anybody thats interested, if your not sure send me a picture of the underside of your car and il tell you if it will fit. cheers rob Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-978398 Share on other sites More sharing options...
mist Posted August 12, 2004 Share Posted August 12, 2004 i've had 6 bolt S13 diff + 2 way LSD in my R32 for ages. All are R200 diffs. Just need the correct side shafts + drive shafts to suit the LSD centre. Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-978431 Share on other sites More sharing options...
rob9246 Posted August 14, 2004 Author Share Posted August 14, 2004 Diff Is Sold Link to comment https://www.sau.com.au/forums/topic/48683-fs-nismo-2-way-mechanical-lsd/#findComment-981003 Share on other sites More sharing options...
