  • Replies 41
Hey ya'll :(
I wanted to get mah car sprayed over in that glitter stuff, but i dont know where to go or what to ask for
and feel stupid saying "you know, that glitter stuff" lol
any help? and what kinda $$ you think i'd be looking at?
you could always talk to House of Kolor about getting flakes sprayed onto your current paint...
what colour is your car btw?
https://www.sau.com.au/forums/topic/48701-glitter-paint/#findComment-978011
Glitter group buy?
I can get glitter in little tubes for $1.50 each, if we pay cash maybe abit cheaper.
Spray adhesive I think is about $7.00 per can. Now if we get about 10 orders we can get them for maybe $5.00 each.
All we need now is a Spray Booth or someone's garage :ghost:
:jk: :jk:
https://www.sau.com.au/forums/topic/48701-glitter-paint/#findComment-978506
yes its called prizmatek and I have seen it on a black honda civic Spew how ugly. Personally i think it looks like shit and it should stay off anything other than skiboats and hotrods.
Just my 2 cents!!!!
Also I think that either way be it a re-spray or a prizmatek job If its done right and a decent quality job u would be hard pressed to get either done for anything under about $4000 just a guess from my own experiances with colour changes and re-sprays.
Blitz can also probably shed some light on this to as he has recently had a very nice respray done.
Cheers!
https://www.sau.com.au/forums/topic/48701-glitter-paint/#findComment-978548
Cheers!
You get what you pay for. The paintjob on my car took 5 weeks and was worth around $9k
https://www.sau.com.au/forums/topic/48701-glitter-paint/#findComment-978569
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
