Cut engine bay sheet metal for cooler pipes to pass, what to seal bare metal with?
Hello, i recently installed a FMIC and had to cut a hole in my sheet metal in the engine bay, under the windscreen washer water bottle. What could I seal off the bare edges of the cut metal with, that would also look neat? I want to do this asap before it starts to rust.
Thanks.
Repaint it.
Get in there with a rats tail file or dremel if you have one and clean up the rough edges. Sand it, primer it then paint it. You could then buy a large rubber grommit which slots over the edges of the hole, will stop the cooler pipe from rubbing on the hole and looks neat. depends how noticable it is, you could use the an old door or boot rubber seal. Cut the soft weather strip off and use the flexible plastic coated metal stripping. Cut it to size and slip it on. Will do the same job as the grommit but will have a join mark
good luck
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
