On the way home from work, got pull over cause my blow off valve was too loud by an under-cover cop & recieve a defect note. The undercover cop told me that my exhaust noisy, air filter & blow off valve was NOT standard. Pictures was taken during the process for evidence. And that I have to attend EPA test (Lidcombe) blah RTA blah blah BLUE SLIP.
Have anyone gone through this trouble and can advice what should I do next? I got rid off all my stock parts. Can anyone let me borrow they stock BOV or air filter?
Thanks.
https://www.sau.com.au/forums/topic/48758-bugger-defect/
remove the blow-off valve and plug the hole for the test, box up your pod filter, make sure your exhuast is not noisy and has a cat(go to an exhuast shop that has a DB meter). The guy at Lidcombe last time I was there ( got sent there with my wrx which had major mods) was a pretty nice bloke actually.
Lidcombe EPA is differen't to the RTA ,Lidcombe EPA doesn't have an emission tester they only test for noise.
https://www.sau.com.au/forums/topic/48758-bugger-defect/#findComment-984486
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
