ok guys due to a discussion with a few of us in the members rides thread, it seems that an SAU-ACT photshoot will be a nice idea.
basically we just need as many of us as possible to get together so we can take some group photos of our rides (and us). :)
so we will need to find a good time so that lots of us can come (e.g. not at 11am on a tuesday lol) perhaps something like latish afternoon on a weekend as the sun will be highlighting the cars nicely and most of us will be able to make it.
so we will need to decide:
Time:
also does anyone have good equipment? or r u good at photography? if anyone is then we'd be happy to have you there to take pics. my sister-in-law is a graphic designer and has access to some really nice printing equipment so perhaps i can get some really nice, big, glossy prints made up after and give them out on a following meet?
anyway, feel free to put up your ideas and oppinions. lets make it a really nice one!!! :(
Andrew.
p.s. yes Gts_Duy: you can bring the seca lol!!!
https://www.sau.com.au/forums/topic/48765-photo-shoot-its-polishing-time/
  • Replies 330
For sure, loving the idea.
I've got a decent camera, not great, but okay. Has taken many a photo in 1600x1200 resolution, absolutely fine for online purposes, but not so good if you want these high-res glossies.
Anyway, great idea, we can hit up a BBQ, cruise, and photos in one day.
Is anyone particularly NOT free any weekend?
I'm screwed for almost every Saturday,so Sundays are naturally better...Having said that,I might be lucky enough to have the second weekend in September as my rostered weekend off.Maybe a day polishing/detailing on Sat',photo's and cruise on Sun'?Either way,I'm in if it's Sunday Setember 12th!
i reckon i'd be up for that. A chance to meet you all again and have alook at all the purrty cars. also i think the weekend of the 11th 12 sounds good as i've already got it off work and my b-day is the 13th :wassup: . party on the saturday night and a mad cruise on the sunday, wat a sick b-day this is gonna be. :)
yep, sounds sweet for me, i cant beleive the coincidence that your birthdays are on the 13th september....mine is on the 27th of april!!!!! how weird!!!!
lol Angus if u need a ride i should be able to take you, unless u live in woop woop, in that case i suggest u hitch-hike and take a ride from a stranger :headspin:
I don't have a Skyline but can I come along for the cruise???
i dont have a car and i'll be coming (i hope)
and andrew (veilside 33) umm yeah a lift would be nice, but ill ask my parents again and get back to you. Ohh and i live in chisholm.
ohh and whytry ill take that comment bout mine and your age as a compliment, as im glad im finally 15 :headspin:
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
