Well I guess it was only a matter of time before the 9.75s record set by Mario's GTR 700 was broken. An adelaide entrant has clintched top spot with a 9.745. Keir Wilson is the owner/driver of the R32 GTR with an OS Giken 3 litre, hollinger, and TD06 turbos (last time i checked)
Congrats must go to Keir and everyone involved as thats a sensational effort.
With the return of Mario GTR records are set to tumble and with a few big HP GTR's on the build, the competition is finally turning into what I've been hoping it would for at least 2 years.
My question is this: Is Keirs 32GTR now eligable to become a RH9 car? If so, I believe its the first GTR in Australia to be eligable. (Mario's is in the Pro class)
https://www.sau.com.au/forums/topic/4879-new-australian-gtr-record/
I reckon that Kier's car is Australia's 1st recognised RH9 car.
He was road registered, had streetable tyres, what else do you need? He drove it in, ran and drove it out again.
As mentioned above, Mario had the record but ran full slicks in a fully stripped car putting him in a completely different category of ProGTR. I'm hanging to see that car run a "real" time for the amount of HP it's claimed to have (exact figures have never been published).
Congrats to Kier and his crew for making a mark in the Aussie Jap car history books.
The official RH9 sticker reads ;
The street specs of GTR,0-400m 9 second's
Record Holders Club.
Danny(denzo) gave me his RH9 stickers when he stopped draging
his white R32 GTR due to breakages.(has sick drift cars instead)
I believe, in Japan, if a GTR runs street tyres & can drive out to
the track, run nines then drive home again, it is a RH9 car.
There is a fine line though.Most GTRs capable of running nines would be trailered to the track due to logistical reasons.Why wear
out a highly tuned GTR in traffic when you can unleash it on the track?
The problem we have in Australia is that the only "street tyres"
they use in Japan(on all the serious cars anyway) are Nitto Extreme 555R tyres.These tyres are not legal on the street in Australia.Keir puts his on at the Track.So will I when they get here.(in transit now).Most of the fast cars in Jap run rollcages.
Next problem - Once you run past 10.0 you must have a full roll cage with intrusion bars(Andra tech inspected).Up to 10.0 a 1/2
cage with intrusion bar on drivers side is ok.This is acceptable on the street(from a practicle point of view)but once you need a full
cage the car becomes less practicle as a street car.
At this level you must have a triple layer fire suit,fire resistant socks,boots,gloves, even underwear.Also arm restraints or window net plus 5 point harness etc etc.
Once you hit 140mph through the traps a parachute in mandatory.
So to be able to race a RH9 street car in Australia on a regular basis you have to turn it into a full blown, Andra tech inspected Drag car!!! Hmmm. Caught between a rock & a hard place.
While we like to hang on to the "but it's a street car"mentality,
I have had to face the hard truth that an 800hp,quad plate clutch/
holinger sequential/locked diffs,stripped out interior,Nitto wearing
GTR is a RACE car with number plates.Add a roll cage & parachute
and who are we kidding? No turning back now. Reece & Mario have cracked the nines.Now Keir has taken the title back to Adelaide with his beautifully built (Australian delivered!!!) R32 GTR. I am hot on his heels(when my Holinger gets here) & I'm
sure there are a number of other crazy GTRs out there in the wings.Man. It's going to be an interesting summer.
Never know.One day we might have our own competition GTR class!In the meantime, who's going to beat Reece's 9.518?
:burnout:
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
