inark Posted August 13, 2004 Share Posted August 13, 2004 UNDER CONSTRUCTION::: Hi Guys! Just thought i would put up an information thread in regards to our less known model cars for those that are interested or just plain curious. As per the way i do most things on this section of these forums this thread will be locked but if you click HERE you will be able to make comments, ask questions, correct my research errors etc For any information on legal modifications or rules follow the below links: -For VICTORIAN modification laws from VIC Roads click HERE -For QUEENSLAND modification laws from QLD Roads click HERE for a PDF file. (Need Adobe Acrobat of which v6 can be downloaded HERE .) -For NEW SOUTH WALES modification laws from NSW Roads click HERE for a PDF file. (Need Adobe Acrobat of which v6 can be downloaded HERE .) Click on the car your after to take you to the post with the specs etc. A31 Nissan Cefiro Link to comment https://www.sau.com.au/forums/topic/48807-car-specs-state-specific-modification-guidelines-cefiro-cimas-etc/ Share on other sites More sharing options...
inark Posted August 13, 2004 Author Share Posted August 13, 2004 1988 - 1990 A31 Nissan Cefiro As you can see these cars arent much to look at in stock form. For a few ideas on the potential of these cars check out our MEMBERS RIDES section. General Information: The A31 Nissan Cefiro was first released in September of 1988. 15 different models were released from Sep 1988 up until August 1990 until the E-A31 Cefiro was released. (counting same model but different year of release etc) Townride Touring Sports Touring Comfort Touring Cruising Sports Cruising Contrary to much belief certain model cefiros were released in Manual transmission, from the Townride to the Sports cruising. General Specs: Body type: Sedan Drive: FR Displacement: 1998cc Engine Specs: Engine model: RB20E, RB20DE, RB20DET Max.power: 205 ps (150.78 kw) / 6400 rpm RB20DET Max.power: 155 ps (114.00 kw) / 6400 rpm RB20DE Max.power: 125 ps (91.94 kw) / 5600 rpm RB20E Turbo Information: Ceramic Fuel system: NISSAN EGI (ECCS) (electronic gasoline injection) electrically controlled gasoline injection Turbocharger: Intercooled turbo Fuel type: Unleaded premium gasoline Exterior Specs: Exterior dimensions (LxWxH): 4690 x 1695 x 1375 mm Interior dimensions (LxWxH): 1910 x 1425 x 1140 mm Wheel base: 2670 mm Ground clearance: 150 mm Curb vehicle weight: 1350 kgs (auto turbo) 1330 kgs (manual turbo) 1260 kgs(manual RB20E) 1280 kgs (auto RB20E) 1300 kgs (RB20DE manual) 1320 kgs (RB20DE auto) Seating capacity: 5 Doors number: 4 Min. turning radius: 5 m Fuel tank capacity: 65 L Chassis/Suspension Specs: Power steering: Yes Suspension system: front Independent suspension strut type Suspension system: rear Independent suspension multiple link type Link to comment https://www.sau.com.au/forums/topic/48807-car-specs-state-specific-modification-guidelines-cefiro-cimas-etc/#findComment-979445 Share on other sites More sharing options...
