220rwkw is way too optimistic... if you had a bigger turbz i'd believe it.
But as long as the car feels better, dont worry about high reading dynos. Driveabllity is more important
well yeah, i love the way the car feels now regardless of how many kw it reads. for the first time yesterday i almost lost control overtaking someone
feels great, im happy
wont let me upload the graph at the moment
will try again later
  • Replies 44
i think what insant is trying to say is the they've bodged up the dyno figure to make it look like a good dyno tune, also the stock clutch is good for about 180-190rwkw, whats it like at 220?
If the dyno used was Bresciani's then my 220rwkw was backed up at Selectmaz very closely.
It may be possible the turbo has been modified without being able to see the difference. looking forward to seeing the dyno plot.
Where the hell were all you buggers all weekend? Phillip Island was awesome.
  • 2 months later...
have you changed the o2 sensor in the last 50,000 ks? goto autobarn, repco get a ford el faclon oxygen sensor, its a standard bosch or whatever brand it is. should take around 1 hour to install at the most. unscrew old one its on the exhaust dump pipe just after the turbo, right behind the turbo heat shield, cut the plug wires off, and replace with new one. The oxygen sensor has two same colour wires and 1 unique colour wire so you can't get it wrong. Match the two same colour wires to the car loom and the unique to unique on the loom. I was getting 250ks to a full tank. Replaced o2 sensor and got around 350 odd
The o2 sensor is only supposed to last 40,000 ks
yeah its around $100 ish. i paid $125 at repco for a AAA brand one i think.
nissan ones genuine are like $250 or something stupid so if you ask for the ford el or as japcab said that place in bayswater
what size is the 31 fuel tank, i think the 33 only takes like 55 litres tops
whereas the aus 31s and vl (im guessing similar fuel tank) took a good 65-70 litres.
does that sound right? the purpose of the o2 is to save fuel by giving feedback to the ecu, without it (as in dead after 50,000 odd or unplugged) the ecu just never goes into save fuel mode, well at least thats what ive learnt and read up on.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
