Ello,
Im currently looking for a set of used coil overs for my 93 series 1 R33 Gtst.. Anyone have any recommendations on where I can find a set at a reasonable price?
Also does anyone know if you can just install coil overs made for an R33 GTR? (as alot of website label the coil overs "Suit R33 GTR")......
Thanks,
https://www.sau.com.au/forums/topic/48838-r33-suspension/
GTR 1's won't fit mate. I've bought a set of Tein Type Flex for my ECR33. They seem like good value. I ordered through a Japanese company and should be here any day. The cheapest Tein's are the Super Street and they should do a good job. Nengun's prices are competitive.
https://www.sau.com.au/forums/topic/48838-r33-suspension/#findComment-980215
Have you spent any time in a car with Jap Brand coilovers? They mostly seem to be way too hard for Aus roads. I went local Whiteline/DMS and in my opinion even they are to stiff for local roads. They handle fine but you get sick of the bangs and jolts.
https://www.sau.com.au/forums/topic/48838-r33-suspension/#findComment-980244
GTR ones can fit. What you have to do is to chop the base eye bolt fitting off your stock shocks and weld it onto the base (between the forks) of the GTR shocks. The height of the shock is the same in most cases (as far as i know). If it saves you say more than 20% the cost, then i'd do it.
https://www.sau.com.au/forums/topic/48838-r33-suspension/#findComment-980250
Thanks for the advice, and i thought i was asking a stupid question! lucky i asked before buying.... :wassup:
Heres another quickie,
My cars a little bouncey atm, just wondering if i raised my car up an inch (back to 2") would the car still bounce like a rabbit on heat? I know the shocks are on their way out....
https://www.sau.com.au/forums/topic/48838-r33-suspension/#findComment-981068
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
