GTRgeoff Posted March 22, 2005 Share Posted March 22, 2005 Yoshi, I did have a little heavy steering at low speed but some extra caster was added and I haven't noticed it for months. There are no lines on a 33, just electrics but otherwise it's as you said. Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1262437 Share on other sites More sharing options...
YogiR33 Posted April 12, 2005 Share Posted April 12, 2005 Got it in the mail Geoff cheers for that, will put it on once my new rims arrive that way i can do the whole alignment job at Bob Jane in one hit Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1295706 Share on other sites More sharing options...
PHATR32 Posted April 12, 2005 Share Posted April 12, 2005 hey, i removed all ym hicas stuff. got pics if you need it. its pretty easy steve Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1296147 Share on other sites More sharing options...
mitchc Posted April 12, 2005 Share Posted April 12, 2005 Hi, new to the forum:D I've got an R32 GTST which is used mainly for drifting. I have a lock bar with two spacers, two dome nuts and four copper washers. Where exactly does the fluid system get capped? I gather the rack is swapped for the bar and rear lines are removed, but there are quite a few pipes and junctions at the front and that's the bit I'm stuck with. What else can I remove? It's not going to go back on, so reversability isn't an issue. Many thanks in advance for any tips, and pics would be really helpful. Mitch Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1296381 Share on other sites More sharing options...
GTRgeoff Posted April 12, 2005 Share Posted April 12, 2005 Steve, how about post them in my tutorial (in my sig)? Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1296607 Share on other sites More sharing options...
mitchc Posted April 28, 2005 Share Posted April 28, 2005 Okay, removed the rear (Hicas) output from the power steering pump and return to the reservoir. It is now lashing fluid all over the place, even after a short run. Will this be alleviated by removing the internals from the rear of the pump, or will an S13 CA18DET power steering pump with the one outlet fit directly in its place? I'm not sure if it's leaking due to excess pressure caused by removing the rear line and plugging the outlet, but it's a bit of a coincedence if it is. Link to comment https://www.sau.com.au/forums/topic/48844-total-hicas-removal/page/2/#findComment-1324993 Share on other sites More sharing options...
