Ok, I have an R32 GT-R and I just finished purchasing and fitting the following peformance modifications.
HKS 2510's (2)
HKS Super Flow Pod Filters
ARC Intercooler 600x300x76
SARD 750cc Injectors
NISMO Fuel Pump
MALPASSI Fuel Regulator
APEXI Power FC
GREDDY Profec B
Car will run between 22 and 25 psi.
Basically I am aiming for 370 Rear wheel kilowatts, or... 500 horsies at the wheels.
I was going to put Z32 AFM's in as well but they are overpriced brand new... and 2nd hand ones I don't really want at the moment. The GT-R are not that restrictive right?
In the end I want a very responsive street driven car, it also has a double plate Ogura clutch, Tein HA suspension and C's quick shift.
Post your reasons why you think I wont/will make my required goal of 370rwkw.
It will go on dyno next week.
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/
The 25/10s are unlikely to produce your goal of 500 rwhp.
The std afms will run out of resolution well before 500 rwhp. It's not so much a case of restriction, but resolution. The PFC (and any ECU including the original for that matter) uses two 3d maps (one for timing, one for fuel injection). Each map uses load as the y axis as determined by the afm output.
OK, if you run out of resolution for load (ie the afms are beyond maximum resolution) you can only use one load value for both timing and fuel injection beyond this point. This means a compromise in power at best, and engine damage at worst. The cheaper RB25 afms will give you enough headroom for the 25/10s.
Don't get hung up on hp numbers - if you have a good low restrictive exhaust system (you didn't mention what you have) and tune to suit, then you will have a very responsive and quick GTR.
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980297
300 rwkw will be achiveable if you want more power and response cams would help alot the rb 20 or 25 afms will do the job the gtr ones will be too small.I have a friend who had an rb 26 built by hks and that only made 330-350 rwkw and it was 2 wheel drive btw also using 2510's the car was tuned in japan so if hks cant get 370 rwkw I doubt you will.
great responsive package though
meggala
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980326
Hi Gimmick,
On what & who's advice where you told the figure of 370kw would be achievable? Unless your from Western Australia then it would sense :).
Here's why you won't...
1) The standard GTR AFM's max out around 280-300kw at the wheels, so you will need Z32 AFM.
2) I have never heard of anyone making that sort of power from 2510
3) 25psi on Pump fuel will blow your motor sooner than later
Finally, Emre made 400kw at the rears on a mix of C16 and Pump fuel with HKS 2530's @25psi with stock internals. But even he will tell you your motor wont last.
Not really knowing the 2510's that well, I think a stock motor is safe around 280-330 at the wheels.
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980334
Dont worry about a number, fact is for a street car you will have stupid/scary response and power if you current setup is tuned well.
As others have said, its not a bad idea to grab some cheaper RB20 Afms as they are a larger diam unit and will flow a better then the smaller diam RB26 units. You will be already running HKS filters so should be bolt on and your PFC should have them listed so shouldnt require too much in the way of a retune.
But yeh forget the rwkw number, only use it as a measure of improvement over std figure you measured, any gear anytime is the motto of the 2510s, so even if a dyno doesnt claim you have 370rwkws, it sure will feel like it for a while...
And when your current power simply no longer floats your boat the next few bob i have spare id buy some RB20AFMs, then a new clutch then some cams....and its a std motor i would be staying around 20psi.
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980361
I agree with everyone else... You won't make 370rwkw.
But forget about the peak number, that's not what 2510s are made for. They're incredible turbos for street use, with a huge lump of low down torque so you don't have a power curve that looks like someone sat on the bottom half, like a few you'll see running around these parts :)
I don't think the turbos will support 25psi anyway, I'm guessing that they'll run out of puff before then...
Great choice of turbos! Good luck and tell us what you manage to screw out of them!
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980378
mmmm power
i like a man thats not affraid to run stupid boost on a standard engine!!!
make sure you introduce yourself with the engine blow up thread!!!
lol....
If using RB20 OR RB25 AFMs on a GTR i think you will find that the RB20s are the pick as they have the same plug as the RB26 AFMs. (can anyone else confirm this, its what a guy said that bought my old RB20 AFMs)
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-980770
gimmick- you have 3 options in regards to AFM's
1. Buy RB20 AFMs, keep your standard piping and plug (Not sure how much these AFM's are capable of, I'm sure I seen it in a thread somewhere with sydneykid outlining how much power you can gain before maxing out)
2. Buy Z32 AFMs, change your piping to 80mm, and change the plug.
3. Buy Nismo AFMS, keep standard piping and plug, can hold up to 775ps...
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-981594
I agree with all of the above! 370rwkw on 2510's with pump gas is a joke. etc etc etc etc also 25psi with these turboes is also a joke esp with a std internal engine ......apart from that, don't get obcessed with a hp number like so many people do. with that package you will have a very quick street GTR!
just let it go........... :)
https://www.sau.com.au/forums/topic/48845-my-r32-gtr-mods/#findComment-982601
