My car currently had just a catback exhaust and pods, with the boost restrictor removed.
I just had hks 2540's and dump pipes fitted, and ive got a pfc ready to be tuned but waiting on some cam gears to arrive first.
the car used to make 1bar with the factory turbos, now it only makes about .7/.8bar and takes a real long time to make boost (I know the 2540's are laggy but I think this is taking longer then it should)
I went down and bought a simple bleed valve hoping to get a harder boost curve (least come on boost quicker) and maybe raise it back to 1bar, is this a good idea?
Is there any chance of maxing out the injectors or running too rich at this stage at 1 bar with these turbos?
Anyway how do you install the bleed valve into these engines, my mechanic said it wouldnt work plumbing it into the hose that had the restrictor and talked about pluming it into a thin metal pipe on the turbo side as he said that would control both turbos
Is he right or is he making it seem harder then it really is to install this thing
Thanks in advance :headspin:
https://www.sau.com.au/forums/topic/48854-bleed-valve-on-a-33gtr/
The factory hoses are very hard to get access to.
The easiest way to do it is to block all of the old hoses and run new hoses from the intake manifold through the bleed valve, to a tee junction and then to each wastegate actuator. This keeps the hoses nice and short too.
Yeah just get a crappy bleed valve for now, shit i cant even afford a boost controller yet and im running 1.2Bars on the GTS-T also with a GT-2540. Dont know what you mean by laggy, the mechanic when i had it on the dyno said it kiked in very early.
Ɨ
Ɨ
