Hey guys,
last minute decision here!!
What the difference between the gts4 or the gtst ?
I need an answer asap! which is the best car ?
Thanks!
(i need some specs on both cars stock)
The BEST is what suits you and your driving requirements.
To ME, the best is the GTS4! (R32 - TURBO) R33 NA.
In 1997 I wanted an AWD Skyline Turbo and the GTR was over $50K!
So I paid $33K for the GTS4, an Auto, it was available in Black the colour my wife and I wanted. (She had to sell her car so we could buy it :Oops:
Never looked back since, although the Auto needed to be fully rebuilt, -Kevlar clutches 2800 Stall etc. $3K 3mths!
The specs of the RB20 (R32) are very similar in both cars wether auto or manual, but the GTS4 is virtually GTR running gear except drive shafts smaller. So it weighs a bit more obvoiusly. Around 100Kg I think. Has the advantage of AWD and if I want RWD I just pull the fuses to the Transfer clutch pump motor.
OK, so its "Wife of Godzilla" but to me thats the next best thing. :)
Last dynoed at 170Kw but hunting for more. (14.1 @98Mph 2.6 0-60)
https://www.sau.com.au/forums/topic/48858-r32-gtst-gts4-or/#findComment-980484
2.6 60ft ???  That's pretty slow even for a GTS-T.
Scott
Its an auto, and it was my first time out the drags with it.
Probably the last too, considering the damage and time off the road :Oops:
https://www.sau.com.au/forums/topic/48858-r32-gtst-gts4-or/#findComment-980582
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
