Well here's the story, just got new tread's one my car, drop'd it an extra inch and a total wax job.
Thought it would of been good to take it out for a cruise.
[EDIT]
First gear kick'd out, Hit second then PFftTtsShhhIii Clink!!. TURBO BLEW!
and i dont know why?. i was only on .85 bar of boost!. are r34 turbo's that weak.
oh well.
anyways, my question is. Should i recon. /hi flow/ball bearing?
im on a low budget? is that any good.
watta u's recomend?
https://www.sau.com.au/forums/topic/48861-noooooooooo/
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
