Hey guys,
I decided to go for the R32 gts4.
I was just wondering, i have $5k to spend o n the car, for mods etc.. (won't get very far) But can someone make a short list, of some mods, that will help with handling, and also, what are some small mods i should get to improve the power od the car ?
Also, has anyone got any idea on how much a new paint job will cost ? or has anyone got any ideas of a good place to go to, to get it done ? (Im in Victoria)
Thanks
https://www.sau.com.au/forums/topic/48884-my-first-car-r32-gts4/
Obviously i havnt got it yet. Ive just decided to go for it over the gtst, and i only have a limited ammount of cash to spend on mods.
Im still deciding out of 2 gts4's that are on carsales.com.au. Theres a nice Black one for $17.500 which i might go for, but its Auto.
Any idea on a rough cost to get a Auto converted to Manual ?
Thanks
Hey guys,
Thanks
First time you line up with a falcodore at the lights and its like today in Melb (WET) you will know you made the right choice! :)
DO - change all fluids unless already done. Change Fuel and Oil filters.
Check in boot on drivers side for fluid level in AWD txfr case reservoir.
New plugs - Plat NGK's, New panel filter, remove front entry plastic into air box behind headlight but leave bit attached at front to rad support panel so no hot under hood air coming in. DONT put on POD! Remove mesh on AFM.
Replumb waste gate solenoid reference from near Turbo comp outlet to the inlet manifold so better response. Check under plastic boots that go ontop of plugs for arcing of springloaded contacts and file flat if corroded. Fit accurate boost gauge to check no overboosting or problems with vacuum. Do not play with boost until you have the gauge installed. Reset ECU - disconnect bat. then foot on brake, reconnect.
If an Auto dont replace ByPass valve on engine crossover pipe with a BOV -stuffs response and does not need a BOV like a manual. :)
Then...
3" Exhaust / Etc.
1. Decent Service with the most expensive shit you can afford (engine oil, oil filter, fuel filter, injector clean, check belts, coolant, power steering fluid, air filter, a/f meter clean, brake pads, brake fluid, check timing, gearbox oil, new spark plugs)
2. Advanced Driving Course
3. Skidpan day
4. Skidpan day again
5. Trackday
6. Another trackday
7. Yet another trackday
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
