G'day All,
Reverting my car back to a stock ride height, so I have my set of coilovers for sale. They're a Bridgestone Potenza brand and was imported from Japan for my use. It's not height nor damper adjustable, but it does sit lower than stock (approx 1-1.5 inches my guess) Ride is smooth, and not as stiff as a set of Teins that I once had! :D
In total, they've done about 20,000km.
Asking $400 or closest offer, so make an offer!
Please PM if keen. I'm located on the SE side of Melb.
Thanks.
https://www.sau.com.au/forums/topic/48908-fs-r33-gtst-coilovers/
G'day All,
Apologies for the lateness of this reply. I've just been a bit ill of late. Anyway, photos will be available this evening. Again thanks for your patience.
Oh, yeah, they're still on the car at the moment, so yeah will need to pull them off once a buyer is confirmed.
Thanks!
G'day Rob,
Thanks for your offer, I will need your help in changing them over so I'll definitely take you up on that. What do you have on your car at the moment? Stock? I have a set of stock suspensions, but do not have the top "pillow mounts" I think thats what they're called. so yeah, the springs are kinda off the shocks if you know what I mean
But yeah, if you do have stock suspensions, do you want to get rid of them? Perhaps we can work something out and lower the price.
Anyway, to the pics of the ride height
Ey forums have been down...been hanging to see the pictures. Any change i could check them out sometime on the weekend?? Cheers Rob
G'day Rob,
This weekend, sure. You're still in Chaddy right? How's this Sunday sound. I'm located in Wheelers Hill, so get back to me, and we'll arrange a time then.
PS. Do you have any stock suspensions still?
  • 1 month later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
