G'day All,
Reverting my car back to a stock ride height, so I have my set of coilovers for sale. They're a Bridgestone Potenza brand and was imported from Japan for my use. It's not height nor damper adjustable, but it does sit lower than stock (approx 1-1.5 inches my guess) Ride is smooth, and not as stiff as a set of Teins that I once had! :D
In total, they've done about 20,000km.
Asking $400 or closest offer, so make an offer!
Please PM if keen. I'm located on the SE side of Melb.
Thanks.
https://www.sau.com.au/forums/topic/48908-fs-r33-gtst-coilovers/
G'day All,
Apologies for the lateness of this reply. I've just been a bit ill of late. Anyway, photos will be available this evening. Again thanks for your patience.
Oh, yeah, they're still on the car at the moment, so yeah will need to pull them off once a buyer is confirmed.
Thanks!
G'day Rob,
Thanks for your offer, I will need your help in changing them over so I'll definitely take you up on that. What do you have on your car at the moment? Stock? I have a set of stock suspensions, but do not have the top "pillow mounts" I think thats what they're called. so yeah, the springs are kinda off the shocks if you know what I mean
But yeah, if you do have stock suspensions, do you want to get rid of them? Perhaps we can work something out and lower the price.
Anyway, to the pics of the ride height
Ey forums have been down...been hanging to see the pictures. Any change i could check them out sometime on the weekend?? Cheers Rob
G'day Rob,
This weekend, sure. You're still in Chaddy right? How's this Sunday sound. I'm located in Wheelers Hill, so get back to me, and we'll arrange a time then.
PS. Do you have any stock suspensions still?
  • 1 month later...
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
