Hey Guys,
I'm buying a 89 240SX with RB20DET swap for my little brother.
He currently is having problems with the rev limit.
The motor won't rev past 5500RPM.
He has installed three different RB20 ECU's. After about 15 minutes after each ECU swap he's done, the computer trips and wont let the car go past 5500RPM. But, it will rev fully for about 15 minutes after he swaps them.
I have been ragging my mind trying to think of what could be causing it.
I have had this problem on cars with bad boost sensors, where they are overboosting, and the ECU puts a clamp on RPM.
But, the guy I am buying the car from is saying the RB20DET doesn't have a boost sensor.
I have never swapped one and don't have any experience with that motor.
List of things checked/replaced:
ECU (3 different ones)
NEW ECT
air control valve
aac valve
MAF (3 Different ones)
CAS (2 different ones)
Compression tested (145-160 psi across the board)
scoped bottom end (no damage)
igniter chip (2 different ones)
tested all coil packs
Any ideas?
Chris
Heres when he started having problems:
"When I took it to emissions, it was sitting there about 15 minutes, when the water started boiling in the recovery bottle. I turned off the car and let it cool down.
Driving it home, the intercooler hose, hose between pipe and hot side of intercooler, blew apart."
He had somebody tow him home. He had it parked for 3 weeks. Installed the Hybrid FMIC and has had problems ever since.
He mentioned that when in neutral he can rev all the way to redline. It's only when he's underload, driving, that he has this problem.
I just can't figure out why its not sending a code to the ECU. It doesn't make any sense.
I'm wondering if it might have something to do with the wiring on sensors on the transmission.
That doesn't mean much - I once had a truly blocked fuel filter that would allow the engine to free-rev till the cows come home, yet it was virtually impossible to get the car to move from stationary.
Check the available fuel pressure when the problem is happening.
What happens when it gets to 5500? Does it bounce hard off a limiter, does it gradually get slower as it approaches 5500, then just not go any harder? Can it go past 5500 using part throttle or going down a hill? All of these will help to narrow down where the problem lies.
I doubt the transmission or the wiring to/from it is the problem. Basically if you're getting a speed reading, your reverse lights work, and (if it's auto) the idle compensation works when you click it in/out of gear, then it's all working fine.
I think I know the prob.
Are you trying auto or manual ecu's?because someone I know had the same prob with his manual RB20det with a auto ecu,we put my manual one in and she rev'ed to redline. :)
  • 9 years later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
