Where: Oran Park/Drift Land NSW
When: 3rd and 4th of September
Spectators
Friday Qualifing $10
Saturday $20
This is a 2 day event featuring the best drifters from around Australia, Stunt shows, Promo girls and D1 drivers, and The R31 House Racing Team straight out of Japan!!
Entries will open Monday 26th July and close Friday 27th August.
Download entry form HERE
Download Sup Regs HERE
Two categories in this competition will exist:
Privateer Class
Vehicles must be owned by an individual and operated by a single driver for the duration of the event. The emphasis of this class will be placed on the individual drivers of the vehicles.
To enter privateer class please download the application form available as of Monday 26th July and send to relevant department as per the application form. The cost for entering is $80.
Factory Class
Vehicles must be based on industry sponsorship and can consist of multiple drivers per car. The emphasis of this class is placed on the vehicle and its primary sponsor or club.
Entries to Factory Class are by invitation only. To be eligible to an invitation please email [email protected] and provide details of the car, major sponsors, driver experience, affiliated club etc. Factory class is limited to 16 positions. There is no qualification for Factory Drivers. All factory cars will compete on the Saturday. There is no cost for entering.
Entries can be sent to [email protected], posted to P.O. Box 28 Narellen NSW 2567, or faxed to (02) 4646 1674. Payment via cheque or money order is to be made payable to Oran Park Pty. Ltd. Payment via major credit card can be done over the phone ([02] 4646 1004), or details can be attached to the entry form using the credit card application form.
All competitors will need to purchase a CAMS level 2 NS licence. Application forms can be downloaded HERE or can be filled out on the day. Alternatively, a CAMS Level 2 NS day licence will cost $20 and can be purchased on the day.
Prizes
Major prizes will be awarded for 1st, 2nd and 3rd to the value of $10,000 to privateer class ONLY. Both Factory and Privateer Class will receive trophies for 1st, 2nd, and 3rd placing. An encouragement award will also be presented.
EVENT SCHEDULE DETAILS
Drift Nationals Round 2 NSW
Friday 3rd September
Time Activity
0830 Scrutineering Opens
0930 Compulsory Driver Briefing
1000 Track opens for practice
1300 Practice Concludes / Lunch
D1 Practice
1330 Track opens for qualifying
1600 Qualifying Concludes
D1 and Stunt Bike Practice
1630 Day concludes
Saturday 4th September
Time Activity
0900 Driver Briefing
0930 Track opens for practice
1130 Track closes
D1 Practice and Stunt Show
1200 Lunch
1230 - 1305 1st 8 Privateer Battles
1310 - 1345 1st 8 Factory Battles
1350 - 1405 D1 Exhibition and Stunts
1410 - 1430 4 Privateer Quarter Finals
1435 - 1455 4 Factory Quarter Finals
1500 - 1515 2 Privateer Semi Finals
1520 - 1530 2 Factory Semi Finals
1530 - 1545 D1 Exhibition and Stunts
1545 - 1550 3rd and 4th Place Privateer
1550 - 1555 3rd and 4th Place Factory
1555 - 1600 Final Privateer
1600 - 1605 Final Factory
1610 Presentations
1630 Aus Vs. Jap Drift Off
1700 Track Closed
https://www.sau.com.au/forums/topic/48950-sydney-drift-nationals/
  • Replies 52
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
