hey guys
went on a cruise to the hunter valley with some mates today.
it was organised by the rexnet forums, 181 cars turned up.
all up a great day, went via putty road, damn those WRX's stick to the road.
but have a look at the one negative of the day...
https://www.sau.com.au/forums/topic/48956-rexnet-cruise-to-hunter-valley/
Only cop was that marked MY04 WRX cop car he came for half the cruise but had to go back cause he was ono duty. SPEED magazine covered the cruise as well.
By the end of the day the guys had raised $3600 for the Starlight foundation.
nice. always good to see the "no good, hoons/modified car trouble makers" raising money for charity. but enough about my emotional problems
I wish I could have been there. but the current cruiser (datto wagon 1978) doesn't drive well locally, so a long distancer is out of the question.
I feel so sorry for the driver of that EVO, does anyone know if the truckie stopped and got all the details and stuff?
mark
yea they swapped details and all that the dude that owned it didnt really look or sound worried at all.
Apparently he had an EVO 6 before that EVO 8 and he blew the engine at a track day and he couldnt careless.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
