guys on my 180sx, i snapped the bolt where the screw holds down the spark plug case.... the screw is stuck in there... wot can i do? is there a place where i can take it so they can take the broken bolt out? thanx
also i tried to change da break pads but i couldnt push the piston back in... is there a tool i can use?
https://www.sau.com.au/forums/topic/4902-snapped-a-bolt-and-its-stuck/
for the brake piston, try releasing the bleed nipple to relieve the pressure. A big screwdriver or similar is usually able to force the piston(s) back - do one side at a time, then fit new pad, because pushing the opposite piston back (in) will simply push the (now) opposite piston back out.
For the bolt, your local mechanic should be able to extract it with an 'e-z-out'.
Are you trying to change the front or rear pads?
Front: use a G clamp to push them back in.
Rear: Need to rotate the piston not push it straight back in.
You could try with a ez-out screw extractor, except they do seem to like breaking. Even more of a bitch of a job to remove a broken ez-out than a broken bolt. (They are made of hardened steel)
  • 7 months later...
