Hi all, my TX valve is blocked, and i have no idea where it is or what it looks like, im told it will either be in the engine bay or under the dash.
Does any one know/how i can get instructions/help on this issue for relitivley cheap? i know replacing this valve if its under the dash is a pain in the butt and can be expensive, but sumnmers coming and i cant wait any longer.
if you are in sydney and have done this before i will pay you to help me do it.
Thanks all
Craig
In the R33 the air-con evaporator core is behind the glove box.
Remove the glove box
Unplug anything that connects to it
Remove the 2 black clips that keep it together. (one on each end)
Undo both lines into it. (from engine bay)
should just pull out.
The TX valve sits on the core
i think you would need a professonal to do this as it is part of the air conditioning sealed system.
i could be wrong though.
yer best to get a pro.. as u sed its a sealed system and u dont want any moisture in there. plus u have to take all the gas out and vac it.
yea i know, but its goonna cost big buks if i can remember i had a VL that needed 1 and it was gonna cost like 600 to fix it...
hmmmm ill do the ring around
just get in there with a 12" and bash the **** out of it to see if it opens up.. its either stuck or blocked so just whack it :(
Once you pull out the glove box you will see...
There are a couple bolts that hold the unit onto the firewall, and jus the clips that join it to the other ducting.
A plug here or there on it too.
It is simple to get out, if you have a bit of a clue you will find it easy too.
well as being as air con fella my self ive found that a air con system i presurised so if you gunna go crackin valves or fittings be prepared for a lot of cold cas and a bit of oil exiting the system
i would get a pro to vac the system a colect the gas
it aint hard but there probaaly is a reason its blocked as in something got stuck in it
so you might wanna look into it a bit more than just replacein a tx valve
just my thoughts thats all
thanks mate, but how much u rekon it would cost?
  • 3 weeks later...
when i first bought my r33 the air con didn't work because it was missing the belt. So replaced it and went to get the A/C regased. The guy at aircon place told me that now the compressor was caktus. I was told this was due to the tx valve blocking up and causing back pressure and resulting in the death of the A/C system. So ended up replacing the tx valve, the dryer unit and the compressor and obviously a regas. All new parts ending up costing 1000. But to me anyway well worth it rather than risking a second hand compressor unit.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
