  • Replies 60
Originally posted by Black33
Inasnt - I tried to find a place that could make them up about 6months ago cos I had seen a s2 like ours in the city with them (white one). I couldn't find anywhere that could make up series 2 ones except the people at www.suborn.com.au said they could make me some in fibreglass if I took my car in (they are in melbourne)
Can you let me know how it goes bcos I'd really like to get some if the ones you get made up by fatz look good.
thanks mate
ps. dave - you can get some for a series 1 from unique autosports.
man can u take your s2 down and get the template made for it?
u owe me for the dump pipe..:mad:
Guest Boxhead
well the point of having em on an r33 is to make the lights more slim line with the grille like on the r32 gtr, or open grilled gtst...
:D
personally i dont see any other point, and cant see myself ever putting em on, but i would like to say i like nice shiny headlight surronds like myn, not like most r33 which is black around each light...
Originally posted by GR33DyMANGO
yer i agree. they arent very nice eyelids. they;re also a little dangerous as they are blocking the indicator light.
You do own a series 2 r33 gtst dont you ??
Well you should know that they arnt indicators then ...
Guest tgriffin
Hey!
Your mailbox was full so I couldn't PM you..
Hey mate!
Any chance you have more photos of your black S2? My mate is tossing up between a white and a black one!
PS. how much did the clear indicator covers/lights cost you? (I noticed both your front bar lights are clear)
Cheers,
Tim
thanks mate
Originally posted by tgriffin
Hey!
Hey mate!
Cheers,
Tim
Ive got pics of my black S2 R33 at www.exstatic.net
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
