Yes many wonder and think we are cheating, and well yes we are. I thought to disclose some of our secrets of our zed tt race car and why it goes so well. Yes Nissan make some things universal to different family of cars and engines as we have found over the years of checking. My zed actually has quite a few GTS-T and GTR bits including.
Nismo GTR bushes in diff and control arms. Nismo don't make much for zeds adn don't even know that some GTR bits fit zeds as not listed in their catalogue.
R32 GTR Cusco upper rear adjustable control arms. A bit heavy though soon to go chromolly custom.
Modified NISMO R200 R32 GTR diff centre with R32 GTS-4 crown and pinion 4.375 ratio. About 20 kilos lighter, much better ratio than the heavy zed 3.7 which is also a slushy viscous coupling.
Tomei GTR solid lifters, valve springs, retainers and shims. converted from hydraulic lifters similar to RB20 and 25. Solid lifters seat better at higher rpm and accommodate custom cams.
Turbo's are similar to N1 but are actually new 200SX S15 ball bearing.
Soon to have N1 silicon crank and cam seals, yes VG and RB same here and N1 stand more punishment with heat I guess and are orange in colour.
Did have R32 GTR water pump pulley with holes drilled to suit 300ZX 4 stud viscous fan. Being larger but same offset and belt size, this slowed the water pump down so it did not cavitate as much at high revs. I now use electric water pump and thermo fan.
Motor going back in next week with R33 GTS-T lighter alloy power steering pump rather than heavy zed NA cast iron one I have been using. Yes thanks to Nissan bolts straight up other than high pressure hose so getting this moded to suit.
Nismo R33 GTS-T gear box mount. New alloy light weight body rather than steel factory one, and is also stiffer for better throttle response and less energy loss.
Nismo 555cc RB20 top feed injectors with custom fuel rail that sits above factory plenum instead of below the plenum. Instead of factory side feed. Also was able to use custom alloy high flow fuel rail, and open up engine for better cooling as it keeps the fuel rail out and away from hot engine block and heads. Plus as a bonus the injectors were incorrectly ordered by a customer a few years back and I thought may as well use them.
R33 GTR accelerator peddle which has a bulge at bottom for heal toe. No GTS-T's don't have and YES GTR peddle also goes straight on and only about $15 from memory.
I am sure this is not the end of it and it does seem to keep happening.
Lots of other parts fit such as R32 or R33 GTR brakes but went 6 piston.
Zed and R32 GTR have same gear box by they way. As in the middle bit with the gears that is. Lots of other bits I won't go into here. I have only listed what is better for zed.
Not sure what Zed bits a GTR would want other than AFM and motor.
OK who's first Skylines Rule etc etc.
https://www.sau.com.au/forums/topic/49063-zedtt-race-car-with-skyline-bits/
Bottom end is built and the rest of the motor is going back together over next week, then she goes in. Did a few mods such as custom cams with 10 degrees more lift, extrusion honed the factory exhaust manifolds and did some match porting and a few other things. It has a big SKYLINESAUSTRALIA sticker on the back maybe a GTR sticker on the front hey?
Duncan how is your GTR going and are you coming to our track day for the big GTR v ZED challenge?
Ummmm I think my Skyline has something from a Zed... Ummmm Ummmm , let me think.
Oh Yeah - I remember.........
The Nissan Badge.
JP I don't know why you go to all the trouble of making your VG more like an RB - just put the RB26 DETT in it and be done with it mate. Will save you heaps of the R&D you are doing that prooves RBs are superior to VGs and VQs.
:cheers: he he ;)
Well there have been a few conversions to RB26 into Zeds which is backwards wondering if anyone would go the other way. Big prob is the 4 wd set up.
The new generation ALLOY block VQ30 is the way to go which many of the Jap GTR GT500 Circuit cars are using.
pfft don't worry about the small VQ30 go straight for the big block VQ35 ;)
They are expensive and hard to get but looking into stroking the VQ30 to VQ35. Getting info from Nissan re this, probably same block just different sleave, pistons and rods. We will be getting ARGO rods anyway and forged pistons so no biggy there. 100 kilos lighter with more HP and torque and maybe two Disco Potatoes and wacko probably 450rwkw with out too much lag. The new Nissan range is strong, nicley balanced and not only much lighter but much lighter rotating mass. We pulled appart a VQ30 NA that we are using as a jig and as a test we weighed the scond hand pistons and rods together, not cleaned so had some carbon and oil, the maximum variations was .5 of a gram. To give you an idea this is one small posted note. That is VERY good. A workshop near us was rebuilding a 350 Chev V8 boat anchor Commodore motor and just pistons alone were 8 grams difference and they were new.
  • 3 weeks later...
Also has R34 GTR rims on it thanks to Steve at Just Jap which we used at Drift Nationals. They realy suit the car and the GTR badge on the centre caps look the part. We actually used a VQ30 all alloy power steering pump on it. Not sure if I mentioned but it also has R32 GTR Nismo diff mounting bushes.
I imagine you have passed a casual eye over this animal...Autech Tsukada Z32, basically VQ35 with HKS 3037. I like the idea of twin GT28s better.
Hope UAS go thru with it, when i win Powerball ill pay for the container over to Japan with some Aussie built cars, could even perhaps surprise a few ppl
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
