What should this run?
By CanadianGuy · Posted
I was reading that the other day, 25 heads aren’t too pricey here thankfully. Now just have to weight the cost vs what I’m getting out of it on doing a rebuild on the rb20, picking up a rb25, or building a rb30. Not really interested in doing a stock rebuild on the 20, but stock 26 cranks & rods seem cheap. Decisions decisions -
You guys are amazingly knowledgeable and I appreciate it all so much. I’m currently at the local RB tuning shop, getting her inspected and diagnosed, for the t-case debacle and everything else. I’ll keep you guys posted!
Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts. -
I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting. -
Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
