Hello,
I need some help translating this tip for Choro Q3, sorry its not skyline related, but i've been playing this game since 1998 trying to find all the 100 event, and at last only 1 remains!!
here it is
コメント:
チョロQ3に関してです。
[花火をいつ使えばいいか?]夜のシティーに出て、
掲示板15を見ると、自動的に使われます。
[火事の消し方]消防車(チョロQ70号)で
昼のシティーに出て 通報があったら
現場のガレージに直行して 炎に突っ込むと
And, yes i did use babelfish and here is what i got :P
Comment: Is in regard to チョロ Q3. [ Should the fireworks when have been used? ] Appearing in the city of the night, when you look at bulletin board 15, it is used automatically. [ How to turn off the fire ] the fire truck (the チョロ Q70 number) with appearing in the city of the noon, when there is information, going straight to the garage on of site, when it thrusts to flame
Can't make a lor of sense from it.
thanks a lot (and sorry if this goes against the forum rules)
Go GO Choro GO!
btw is this game big in japan?
https://www.sau.com.au/forums/topic/49068-help-translating-this/
here's what systran spits out
comment: -- CHORO Q3 -- being related -- て -- it is . Is what is necessary just to use [fireworks when?] If it appears in the city of night and a bulletin board 15 is seen, it will be used automatically. It appears in the city of daytime by [how to extinguish fire] fire truck (CHORO Q70 No.). If there is a report, it will go to the garage of the spot direct. If it plunges into a flame
Thanks funkey, but babelfish uses systran too. so the translation is still not very understandable.
From what i can understand, it says to use bulletin 15 to activate the fireworks at night. Then you have to use the fire truck to extingush the fire in the day.
still the last sentence amazes me "If there is a report, it will go to the garage of the spot direct. If it plunges into a flame"
are they saying that the garage will burst into flame if there some report or information??
I wil try jiggling with the game maybe it will work.
lol, finally got it, it just said to start the fireworks in the night, then go to a certain street in the day, after that YOUR garage will burst in flames and you'll just have to drive through the fire to clear the event.
phew that was.....EASY.
Now that the game is completed, want to know what you get in the end...a NUMBER. and one that i dont even know what to do with it. still I feel satisfied.
and this game does have a lot to do with skylines. virtually every one after 1960 is there, and guess what car do i use . heh the one in my sig, just a police car.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
